Question about SanDisk Sansa E280 MP3 Player
Q see fail to connect the device in main connection
Netflix wont connect on my apple tv and i'm connected to the enternet
  1. Test the Internet connection on the Apple TV
    1. From the main Apple TV menu, navigate to Trailers.
      • If you don't see Trailers: Select Movies, then In Theaters.
    2. Select any title and click Play. If trailer plays, the device is connected to the Internet.
    3. If you are unable to connect to the Internet, you may be having network connection issues.
  2. Restart the device
    Restart your device by unplugging it from power for at least 10 seconds, then plug it back in and turn it on with the power button. Restarting the device is often enough to restore your ability to connect to our service.
  3. Disconnect Apple TV from your Netflix Account
    1. Navigate to the main Netflix menu inside the application and click Logout.
    2. Select Yes.
    3. You will be returned to the Apple TV's main menu, at which point the device has been successfully disconnected from your Netflix account. You may select Netflix to sign back in with your account information or connect as a different user.
  4. Troubleshoot your Internet Connection
Oct 23, 2013 | Netflix
My wireless won't connect to the internet. The switch is on. The laptop can connect when I use a cable.
Try downloading the latest drivers from Toshibas site
If that fails, open the base of the laptop (should be a cover there), check that the wireless card is installed and the two wires that attach on push posts are present and attached. One is black (main) the other white (aux).
In device manager, check that the wireless hardware is detected, if it is not seen and the card is presnt and connected, the wireless controller has failed, or the card itself is damaged and will need replacing.
Jan 30, 2011 | Toshiba L305-S5955 Notebook
My phone samsung gt-s5233w cannot connect through wifi connection..everytime i try to connect the device, "dns failed" is always displayed.
my phone samsung gt-s5233w cannot connect through wifi connection..everytime i try to connect the device, "dns failed" is always displayed
Aug 04, 2010 | Samsung Star GT-S5233 Cell Phone
Is it possible to use motorola w230 with a pc as a usb modem
My battle with moto. phns. lasted aprox.2 months and 300+$ .main factor ur. carrier its that easy.ask! I purchased the software +2 diff. phones .There is no slick way.good luck
Jun 21, 2009 | Motorola Mobility W230 Phone US with...
Connection Problem
update the firmware of the all device
Feb 23, 2008 | SMC EZ Connect g SMCWEBT-G
Load main image failed?
Hope this would help. Have you updated the firmware of your player? Try updating the firmware of your player. When the player is turn off slide the hold switch for it to show orange/red color. Then press the Record and the menu button until is shows on the screen welcome to recovery mode. Then go to sandisk website and download the firmware update and install it to your computer. When it ask you to connect a device connect the player and update the firmware of the player. If the update is successful then it would ask you to choose a language. Hope this helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
