Question about Goodman CKL60AR60 Air Conditioner
Outside ac unit working inside not - Goodman CKL60AR60 Air Conditioner
    Genius:
  • Goodman Master
  • 1,363 Answers
Fan relay, capacitor, or fan motor.
Posted on Aug 12, 2015
22yooper
  • 828 Answers
SOURCE: Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Posted on Jun 27, 2008
  • 10865 Answers
SOURCE: Inside fan running outside not
There is an electrical box on the wall near the outdoor unit. open it and be sure that the circuit breaker is in the on position. Same in your electrical panel, be sure that the circuit breaker is turned on.
Posted on Aug 16, 2009
heinzhvac
  • 229 Answers
SOURCE: outside unit doesnt start inside unit is working
This model of Goodman A/C the condenser coil get extremely dirty and what happens is when your condenser runs for a long period of time it pops the capacitor. This is the starting component for the compressor and the fan outside. the coil needs to be cleaned with a non acid condenser cleaner. Open up the side compartment of A/C look at the silver cylinder thats the capacitor if is looks swelled replace it.
Posted on May 11, 2011
kingbrizzle
  • 407 Answers
SOURCE: Have ice build up on line leading into outside unit and ice buidup on inside units on my goodman air conditioner
Turn the system off on the thermostat and set the fan to "ON", this will thaw the ice faster if it hasn't already. When the system has completely thawed, which could take hours sometimes, depending on how bad it's frozen, then turn system back to "Cool" and start these checks>
1. Make sure filters are clean!
2. Make sure there is proper airflow through vents.
3. Make sure outside condenser fan motor is running.
If you have either no or minimal airflow, check the indoor blower to make sure it's working, if it is, the evaporator coil is dirty restricting the airflow. Be sure the system is thawed because the ice will also block the airflow!
If the condenser fan motor is not running, either the capacitor or the fan motor will need to be replaced.
If your filters are clean, you have good airflow through the house, and everything comes on like it should, it will most likely be the charge of refrigerant in the system is too low and you have a leak somewhere. If you have to have it charged, be sure the system is thawed before the technician gets there, he will not be able to do anything while it's froze.
Hope this helps and good luck!
Posted on Jun 10, 2012
  • 3 Answers
SOURCE: Outside AC unit not blowing - Goodman dk-36-1d
1. check to make sure your 220volts is there at disconnect box.
2. check if you 24volts at contactor at the outside unit.
3. if you got it all check the capacitor.
Posted on Aug 14, 2012
Unit stopped cooling, inside unit runs, outside unit does not
could be a gas leak ( low gas pressure shut off switch, failed start run capacitor for the compressor , vermin problem shorting out the power board outside
The inside unit is just a fan
call an accredited ac technician to get a proper diagnosis and quote
Aug 06, 2016 | Heating & Cooling
Air con has water dripping out the front
Does the fan work to evaporate the moisture? ACs are pretty easy to diagbose. Is it dripping in the house?
Mar 26, 2016 | Heating & Cooling
My outside unit is making a loud weird noise but the inside unit is working completley fine it is 7yrs old now
the outside unit is where it all happens. That is where the compressor is and its cooling fan. The inside unit is just an evaporator, a bit like a car radiator and a fan. The inside unit is protected by the room, the outside unit is in the rain, snow and wind.
You need an AC engineer.
Feb 01, 2016 | Heating & Cooling
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
I have a 2.5 ton ac outside. the indoor unit downstairs in the basement is a goodman. a new a coil was put in about a month ago. which is a goodman product. ive heard goodman is not a good product. a
the inside coil and outside unit should be matching in tonages another word if you have 2.5 ton outside the inside sould be the same. it don't matter what brand name or who made it.
Aug 04, 2012 | Goodman CKL36AR36 Air Conditioner
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
Outside unit come on for ac but inside won't come on for ac or heat
Turn Tsat to fan to see if inside unit will come on. If it does Tstat needs replaced. If not it is fan motor or fan relay. Possible cap. Do you here the fan relay come in. If it is a Good man unit it is time delay and you wont here it. Need to know your make of unit. Rusty
Apr 25, 2009 | Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
27 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
