Home | Bosch | 36 Inch Pyramid Chimney Hood - Black | Bosch dishwasher mod...
Bosch 36 Inch Pyramid Chimney Hood - Black
Problem for Bosch 36 Inch Pyramid Chimney Hood - Black
Bosch dishwasher model SMU4052UC/14, Won't fill
By epplings on May 06, 2009
Bosch dishwasher model SMU4052UC/14, Timer clicks and moves,light comes on,but will not fill with water. No noise from pump.Took dishwasher  out,no water where it shouldn't be. How do I test the components to figure out what part isn't working?
Solution #1
posted on May 06, 2009
Somewhat Helpful)
speeddemon97
Rank: Guru
Rating: 90%, 121 votes
you need to check the water solenoid valve. if you follow the water line coming into the dishwasher you will find the valve(first spot in the water line with two wires coming from it) if you pull the wires off you should see 110 v when it is trying to fill with water if you do then test the valve for continuity.
Was this helpful?
Yes
No
Popular Solutions for Bosch 36 Inch Pyramid Chimney
Questions and Unsolved Problems for Bosch 36 Inch Pyramid Chimney
Do you recommend Bosch 36 Inch Pyramid Chimney Hood - Black?
Answer
Answer
I moved into a new home. Has a 36" cvaliere range hood over the islanded vented out side. 3... (More)
Answer
cooker hood motor not working after a loud bang
Answer
bosch dishwasher (approx. 5 years old), won't close - is it a problem with the latch? What do i do,... (More)
Answer
do i need to check the drain hose to see if it is plugged up,replace the pump. is their other ways... (More)
Answer
i have a bosch dishwasher SGS69L02GB/17.The door handle is broken,got the spare handle but cannot... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 36 Inch Pyramid Chimney...:
Top Kitchen Hood Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Kitchen Hood Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
