Question about Samsung 226BW Monitor
Samsung monitor light blinking no picture - Samsung 226BW Monitor
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
When I turn on computer,monitor doesn't show anything sometimes 1,2 hours , and then finally I can see descktop on computer...All that time,monitor is trying to show picture (I can see like blinki
This is a known symptom of a failure in the power supply board. Here is a link to a repair guide that shows how to dis-assemble and the unit and then what to look for and replace on the power supply board to bring the unit back to working condition.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board that needs to repair.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 22, 2012 | Samsung SyncMaster 940N Flat panel Monitor
Samsung led monitor blinks on pc but only on desktop picture
presss four buttons on the control panel simultaneusly and keep pressed untill
unlocked message will appear when unlocked message will appear your problem will be solved .all procedures will carry in power on condition
Oct 31, 2011 | Samsung SYNCMASTER 570DXN MONITOR 58.1 X...
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
Hi, I got problem with my 226BW Samsung. Some time it started. The blue light on the monitors blinks (normal) but no picture, also not menu or anything. After a few minutes it blinked shortly and than it...
Sorry, the links you provide does not work. You can post the picture her at FIXYA but it has to be less than 150k in size.
Do you see caps with dome top (not completely flat)?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Samsung 226BW Monitor
I have a SyncMaster 920N Samsung Monitor and today it stops working. The power light is slightly constantly blinking,but the monitor is not turning on,when I m pressing power button. I tried changed power...
A fast blinking power light is an indication that the power supply is in a shorted condition. Parts called capacitors that filter the output power on the power supply board can fail and the power supply will short out causing the fast blinking power light. If you can solder then you can repair the monitor. Here is a link to a repair guide that has pictures and videos showing how to dis-assemble the unit and what to look for and replace to do the repair.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
BuddyMc
Jan 06, 2011 | Samsung SyncMaster 920N 19" LCD Monitor
My samsung LCD monitor display blank but blue light is blink.
Check to ensure all connections are in good place and are properly connected, if they are and yet no display, the picture board on your monitor is faulty, since the power light is on, it means the picture board of your monitor has developed fault.
take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Dec 10, 2010 | Samsung SyncMaster 740N (Silver) 17 inch...
Hey Experts! I need assistnace. My Samsung 2043BWX 20" monitor is black (or blank). I do have a flashing blue LED next to the power. When I plug the monitor in a power supple without being connected to the...
Actually, the ultra high voltage 'charger' for the florecence (a.k.a. your back light)has gone Kaput...
If your lucky, someone will have a monitor like yours that has the back light come on, but no picture (should get a similar blinking light situation, but a different code. Like... blink, hold, blink blink, hold, blink). In this situation (if your comfortable doing it) you can swipe the exciter from that monitor and put it in your monitor. Obviously this is a more economical way of repairing the monitor.
Just to be on the safe side (as the repair is blindingly easy. 6 screws, pop out, pop back in) DON'T touch any of the back side components. You WILL shock the supreme **** out of yourself. Between the heavy duty capacitors and the ultra high gain transformers on those things you could jump start a bus. So don't be fooled... those little transformers pack a mean sting.
Hope this helps...
Oct 11, 2010 | Samsung 2043BWX 20 inch Monitor
Samsung 720n power light blinks, no picture.
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with this problem - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Apr 20, 2009 | Samsung SyncMaster 720N Monitor
BLINKING OF SCREEN
check for Dry Soulders & FBT....
Jan 06, 2009 | SAMTRON 55V 15" CRT Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
22 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
