Question about Toshiba 27A33 27" TV
How to operate toshiba remote control - Toshiba 27A33 27" TV
I lost the instructions for operating my 3300 one for all remote control. Please help me program my Toshiba tv so I'll be able to operate my tv set.
Turn on your Toshiba TV. On your remote, press the TV key. Press and hold the SET key depressed until the red LED blinks twice, then release it. Press the 0, 1, 5, and 4 keys. Point your remote at the TV and press the POWER key. Your TV should turn off. If not, repeat the programming routine pressing the 0156, 0060, or 1256 keys
Oct 03, 2013 | One For All URC-3300 Remote Control
Manual for toshiba ct-90325 remote tv
Can't find a manual for this remote. However, try this link for a way to get it to operate:
How to Find Codes for Toshiba Remote Control Techwalla com
May 11, 2012 | Toshiba Ct90325 Remote Control
My toshiba 62hm84 was given to me without remote control. Can I operate it without it or do need to get a remote.
The remote control for this model is no longer available through Toshiba. You can operate the set but will not be able to use the picture size features. You should be able to work the main functions and also access the picture and audio on- screen adjustments. If you find a vendor that happens to have miscellaneous remotes, the remote number is CT90164.
I hope this helps,
Skyassoc
Dec 11, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a Toshiba tv/dvd combo. My remote will not operate the dvd
You might have to re-program the remote, here is the link for the owner's manual which tells you how.
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
Feb 19, 2009 | Toshiba CT-90157 Remote Control
Programming a remote
Here's the RCR450 Manual =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
The codes for Toshiba TV are Toshiba 1000, 1048, 1072, 1105, 1109, 1118, 1160, 1190, 1241 and are listed in back of the manual.
Nov 14, 2008 | RCA RCR450 Remote Control
Remote control
YES... Get a miracle remote, http://www.miracleremote.com/ for Toshiba and it will operate ALL of the functions like the original including access to the service menus.
Nov 02, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Toshiba 36AF43 will not operate via remote control (Yes, the batteries are fresh!)
try unplugging the tv and allow the tv to remain unplugged for a least 5 minutes. This will force a reset on the tv which should resolve your remote issues.
Dec 17, 2007 | Toshiba 36AF43 36" TV
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Oct 02, 2007 | Toshiba CT-90157 Remote Control
Toshiba 27A33 27" TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
