Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Remote volume control for Sharp Aquos 42inch LCD not working
The remote for my Aquos 42 inch LCD tv is working well except for the volume control which was working until a week ago. I changed the batteries but that did not help. I can change the volume on the TV directly but not with the remote. When I press the volume control button on the remote the red light on the face of the remote flashes indicating the signal is being sent but the volume bar does not show up across the bottom of the screen and the volume does not change. The volume bar does show up when I press the mute button but after pressing the mute button a second time to allow for sound I can hear the sound and I can still see the volume bar for approximately 15 seconds but I cannot change the volume. Again right now I can only change the volume directly on the tv, not via the remote. Please advise. Thank you.
  • 1 more comment
  • rapolley Oct 09, 2007
    The problem was that on the top right there is a function button that was on audio. I needed to press the function button to get it on TV to change the TV volume. Thank you for your help.
  • Anonymous Mar 23, 2014
    The front controls do not function (pwr on, channel up/down, volume up/down, input & menu). TV only operates via remote.
  • Anonymous Mar 30, 2014
    no sound the volume bar stays on the screen showing volume is off. remote wont work and the controls on the tv dont work. Can press source on the tv but it just scrolls through the opitions very fast and wont stop.
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
  • 790 Answers
Ok please open the remote then clean it with pencil eraser.
Posted on Oct 09, 2007
SOURCE:
Need remote for sharp aquos LC42XD1E
Setup codes to Sharp brand TVs with universal remote control are 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122. Just buy a remote control, which has setup codes to Sharp TV. You can get this iformation from the attached specification sheet with each universal remote control If you wish to get more details to different other brand remote controls, check this link.
Feb 06, 2013 | Sharp Aquos LC42XD1E 42 in. LCD TV
My sharp aquos lc-42d65u is not responding to my remote control . another word my t.v does not read my remote control at all. can someone help me to fix my remote ?
U already change the remote control for brand new batteries wright?Yes.Remote controls devices are heavily depend on it CPU chip for all of it functions.Test the tv manual buttons like Power,Menu,Volume - + and Channel + - all work?Yes.The tv remote control CPU is dead that why doesn't read the tv infered laser signal at all.Try website like Remotes.com to buy an original remote for the replacement.
Apr 04, 2011 | Sharp LC42D65U 42 in. LCD HDTV
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
I have a 42 inch sharp aquos i dont have a remote and i'm trying to set my cable channels there is no way i can pull up a menu or nothing from the tv what to do
check ur tv as there will be buttons there where u can set programs and fine adjustments without remote control......if u still have probs ......get yourself a new remote control.......
Nov 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Just bought a 42 inch lg tv and cant programme my
please follow the steps below with you sky remote:
TV
RED + SELECT (hold these down until it flashes twice)
TV
0056
Try the volume button if this works then press SELECT. If it does not work then press TV again then try the volume ( repeat this step until the volume works. Dont forget to press the SELECT button to save the code to the remote.
This should sort you out. Please leave a thumbs up when you get it working.
Cheers Little Dish Fitter
Sep 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Remote control not working on brand new series 4 42 inch samsung
Make sure the remote is set to operate your tv and not a cable box or accesory. It's in the menu
Jul 24, 2009 | LG 42LC2D 42 in. LCD HDTV
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
4,904 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
