Question about Panasonic DMR-E85H DVD Recorder
Frozen up with please wait read out on unit
I was watching a recording on the HDD when suddenly screen went dark , with a flashing white screen about once a second - read out on unit reads PLEASE WAIT - which I did , but nothing happened - The unit does not obey any commands - from remote or directly on unit - When I hit power button 2 small lines light up shortly on both sides of the PLEASE WAIT - but nothing happens - unit remains frozen ----- I have unplugged unit and waited, but no reset - I also disconnected cable line in, but nothing has helped - The day before this problem , I had recieved a signal from my cable company to activate a digital cable box I had just rented from cable company - I wonder if this signal sent damaged my dvd recorder, which was connected to cable TV at the time ?
  • 1 more comment
  • Paul Sandella
    Paul Sandella Oct 09, 2007
    My fuse on power supply board checked out good, and there are no visible signs on any capaciter shorts on power board----------- - an earlier solution on this site for a similar problem pointed to the faliure of 2 caps on power supply board - according to solution, these failures were visible to the servive person - does anyone know what caps these were ? c1126 + c1127 perhaps ? although mine look good - also, is there anywhere a power supply circuit board can be purchased ? I'll just shotgun the problem with board replacement if financially wise - Thanks all !!
  • Paul Sandella
    can you tell me what caps are the filtering caps ? are they c1126 and c1127, and do thay have to be removed from circuit to be tested ?
  • Paul Sandella
    I can't work on it today, I will contact you regarding this as soon as I can - thanks - Paul
    Genius:
  • 1,139 Answers
Hello MrBrokeit, Shotgunning works sometimes, but the effort spent is often not worth the time spent. Let me explain if your power supply is defective then shotgunning will produce results, however if the problem is elsewhere you will never know it. I would suggest troubleshooting the unit, to determine where the problem really is. For this task I would suggest that you get a schematic diagram of the unit, a multimeter, and an oscilloscope. use the schematic to find the various test points, use the multimeter to measure the voltages at the test points, and then use the oscilloscope to measure the signals at the test points. Troubleshooting in this fashion will produce better results than as with the shotgun method. I would suggest checking for ripple voltage in the DC path. This voltage is due to AC bleed over from poor regulation by malfunctioning filter capacitors. you will not see physical signs of the problem but a quick check of the capacitors will let you know if the is the problem. Also check to see if the DC voltage across the positive terminal of the capacitor is held at the level it should be at. Then check all points on the power supply and compare them to the schmatic. Thank you, Shuttle83
Posted on Oct 09, 2007
  • Henry McKelvey
    Henry McKelvey Oct 09, 2007
    in fact you can measure them in circuit since you are actually measuring the voltage across them to determine if there is too much ripple riding on the DC level (use an oscilloscope for this). The filter caps will be the largest ones i the unit. if C1126 and C1127 are the largest then measuer across those.
SOURCE:
Magnavox MDR537H/F7 no power
Some surge protectors cut off all power, when they reach the surge protection limit in joules. Power strips have reset buttons to restore power. Try plugging it directly into the electrical wall socket. If it works, then purchase a new surge protector. The DVD recorder may have a internal fuse that has burned open.
Jun 03, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
No turn on but a message on the display. The message is PLEASE WAIT
This message is displayed when the device is checking for its hard drive and DVD drive to signal back that they are operational. You can consider this a bit like the BIOS of a computer as it is waiting for its devices to come back with a "READY" signal. If "PLEASE WAIT" is scrolling across your screen for a really long time it could mean that the two devices with moving parts (HDD / DVD) may be having an issue coming up. UNPLUG unit from wall. Wait for some time (5 min) and then plug it back in. If your device is still not working then you have either a bum HDD or a bum DVD. Considering which one is working all the time (HDD) you probably have a dead hard drive, but my own unit's DVD drive went nuts, so that is also a potential source of the problem.
Either way, your local computer repair store can have a look at this issue, considering what the unit is is basically a single purpose PC
Graham Leach
Aug 24, 2011 | LG RH-4820 DVD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
May 30, 2009 | Panasonic DMR-E85H DVD Recorder
JVC GZ-MG37U Menu screen won't come on, blue access lt. stays on
you have to check the firewire securety port....
it protect the camera from the wrong conections with the pc...
it doesn"t complot the camera work....
if you have a playback recorder deck it can wait ....
Jan 21, 2009 | Video Cameras
Cannon EOS Rebel XS shows busy display stopped working
Just got a brand new camera. Played around with it a few nights to learn all the parts and buttons. Went to a concert tonite. While waiting for the show I took many test shots to see how the camera would work under these contiditions. Used a 75 to 300 Cannon lens. I had just got the settings about right when the show started. All of a sudden the display went dark and "busy" flashed in the view finder. But it would not take any more pictures. Taking the battery out and removing the sd card did not help. The auto focus and flash still worked but nothing else.
This camera is going back to the store if I can't get some help. PLEASE............. vj
Dec 05, 2008 | Canon Digital Rebel / EOS-300D Digital...
No Sound
I had the same problem but I unplugged the unit to reboot it and the sound came back
Feb 10, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
TomTom Stopped Working
alrighty. i tried to download some voices for it. go to my computer, voices. (or whatever you downloaded) look for the recovered fragment files. Delete them . that helped with my tom tom 1
Mar 11, 2007 | Tomtom ONE GPS Receiver
Panasonic DMR-E85H DVD Recorder Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
