Question about Watts Onan Portable Generator - 4000 , Model# 5500
My generator is putting out too much voltage - Watts Onan Portable Generator - 4000 , Model# 5500
I HAVE A GENERATOR RIDGID 8000, STARTS BUT DOES NOT HAVE VOLTAGE
check the voltage reulator for output voltage
this regulator allows voltage to the alternator windings to generate power and without that voltage there is no generator ac out put
talk with a genset repair shop for a better diagnosis and quote
Oct 30, 2016 | Electrical Supplies
Output voltage adjustment
Output voltage is based on 3600 rpm @ 60Hz. Sounds like your generator is over speeding slightly. Put a Frequency meter on the output of the generator and tune it to 61.5 Hz, that will get your generator in the 3600 RPM range.
Jul 17, 2014 | Dewalt DG7000 Heavy-Duty 7000 Watt Gas...
Low voltage
You have overloaded the generator and have blown a capacitor, resistor or similar item that will only allow half the voltage output to the recepticals. I know I have done this too.
Dec 05, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
Briggs and stratton generator keeps throwing the circuit breaker
Power tools CAN draw heavy loads if the voltage or frequency is off. Both of those CAN be a fault of the generator.
Check the frequency by plugging in a clock with a moving second hand and time it for 10 minutes against a quartz clock. ALSO do a voltage check with another voltmeter.
The 5500 Watt generator should hold 40 amps. Power tools with induction motors like some table saws take a large starting load near this value AND would be sensitive to low voltage AND especially low frequency, both of which will cause much higher current draw.
One MIGHT have to resort to put an oscilloscope on the output to make sure the waveform of the AC output is normal..
Apr 03, 2010 | Briggs & Stratton Power Products 5,550...
6000w gas generator putting out low voltage
Your voltage regulator is at fault. Make sure you replace it with the exact same brand name and serial number or you will burn out the generator.Thank you, Dana
Oct 06, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
RV Onan 4000 runs fine but not putting out enough voltage to run anything
Not sure how to set it up but you can take it and have the voltage turned up on your generator or the voltage regulator is out.
Sep 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
No output from my generator
check breaker, your outlets should be like a gfi
May 21, 2009 | Coleman Powermate Premium Plus 6250W...
Three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Apr 01, 2009 | Coleman Powermate Powermate 5000W...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
