Question about HP LaserJet 4 plus Printer
Error code 14 "no tuner cart"
I have a problem in my printer hp laserjet 4 plus error code is 14 no tuner cart
    Problem Solver:
  • 11 Answers
14 NO EP CART Message
The printer detects the presence of the Toner Cartridge and the
level of toner present in the cartridge through the condition of the
ANTIN signal. The ANTIN signal becomes part of the serial data
stream used to communicate with the DC Controller (see Figure
7-5 for cartridge components). Troubleshoot the 14 NO EP CART
(or INSTALL TONER CARTRIDGE) message as follows:
1 reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
2 Check the High Voltage Contacts for damage. If the contacts
are dirty or damaged, clean the contacts after the repair.
3 Replace the High Voltage Power Supply.
4 Check and reseat the HVPS cable.
5 Replace the DC Controller
Posted on May 21, 2009
Just purchased a used HP LaserJet 4 Plus -- when turned on and installed it is showing 14 no EP CART -- we do not use cartridges so need to reset to default settings. Tried Power On and holding online but...
Ensure that the Toner Cartridge is installed correctly (fully
seated into the printer). Try a new Toner Cartridge. If the
problem continues, try this
1 Reseat the Toner Cartridge. Try a new or known good Toner
Cartridge.
5 Replace the DC Controller.
Jul 05, 2011 | Office Equipment & Supplies
14 no toner cart
when top door , and check for the sensor switch
Jun 17, 2010 | HP LaserJet 4 plus Printer
HP Laser Jet 4 Plus error code 52 What do I do now?
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Jan 18, 2010 | HP LaserJet 4 plus Printer
After installing a new toner cartridge in my HP Laserjet 4Plus, I have an error code 14 no toner cart and cannot print.
1. Reseat the cartridge. Try a new or know good cartridge. If OK, stop.
2. Check the Hi Volt contacts on the cartridge for damage. If the contacts are dirty or damaged, clean the contacts after the repair.(This is especially important if the cartridge is recycled.) If OK, stop.
Before going further, evaluate the cost effectiveness.
3. Replace the Hi Volt Power Supply. If OK, stop.
4. Check and reseat the HVPS cable
5. Replace th DC controler
Oct 07, 2009 | HP LaserJet 4 plus Printer
At times i get a message 14 no toner cart and then i am unable to make prints
No Toner then it prints again..
This could be lower toner, a generic toner cartridge will sometimes produce this, or dirty contacts where the cartridge lays in machine.
Look at the toner cartridge, where you see shiny silver or bronze, clean excess toner off, also in machine where toner cartridge lays, clean all excess toner out.
Oct 03, 2009 | HP LaserJet 4 plus Printer
My printer keeps printing black smudge like lines on the sides of the paper. Can you tell me what this might be?
usually its a defective toner cart. recycled carts are just refilled, they are not reconditioned. I would remove that cart, clean the mechanism, and replace with a new cart.
Jul 21, 2009 | HP LaserJet 4 plus Printer
My Hp laserjet 3600n printer gives error code 59.63
59.53 ERROR
59.63 ERROR
An error occurred with the yellow printcartridge
drive motor during startup or
rotation.
A problem with the Yellow Print cart. If you changed it recently try changing it again. If not the cart. then the unit may need a motor or board.
Jan 12, 2009 | HP LaserJet 3600n Printer
'14 no toner cart' problem to be solve
It has a chip on the toner cartridge, chip is bad. replace
Sometimes the sensor in the machine goes bad. replace
Jul 24, 2008 | HP LaserJet 4 plus Printer
Laserjet 4 plus printer
printer keeps running until paper tray empty, msg 41.3
Jun 03, 2008 | HP LaserJet 4 plus Printer
REPAIR
Yemmitty,
According to the HP LaserJet 4 plus service guide. Your error code of 57.1 indicates the following;
1) The printer's gears are siezed
2) The DC controller or main motor is defective.
Nov 10, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4 plus Printer Logo
500 people viewed this question
Seeker5211
Seeker5211
