Question about SanDisk Sansa c240 MP3 Player
Sansa C240 freeze, wont turn on
Tried everything!
On my C240, when it freezes, I can remove the battery and re-insert it.
Posted on Nov 03, 2007
  • 626 Answers
Try a hard reset. Press and hold vol + and select for 20 seconds. If that doesnt work, you can try holding the power button for 30 seconds. Try to restart after either trial. If that doesnt work, you can call support and they can troubleshoot it for you. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Posted on Oct 09, 2007
2 Suggested Answers
  • 1234 Answers
SOURCE: Sansa c240 (1GB) MP3 Player: i have a sandisk sansa c240 and a 2gb micro sd car...
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Posted on Aug 30, 2010
It wont format, it wont let me delete or even add songs? what do i do?
There are two to reformat your device. Just follow these instructions
From menu of your device:
1. Turn on your Sansa C240
2. From the main options menu, select " Settings "
3. Select " Format " and " Yes "
Formatting Manually:
1. Turn off Sansa C240
2. Slide the " Hold " switch on the bottom of the device to the " On " position
3. Press and hold the " Play " button. Press and release the " Power " button.
4. Hold the " Play " button until the LED screen displays the message " About to format device."
5. Release the " Play " button and press the " Next " button once.
Try these steps and let me know if you manage to reformat your device.
I could instruct you on how to reformat this device on your pc just post back.
If these solutions helped you.. please rate this answer and leave some testimonial too.
Thank you
Nov 17, 2010 | SanDisk Sansa c240 MP3 Player
May 17, 2010 | SanDisk Sansa c240 MP3 Player
How to Add 16G Micro sd card to Sansa c240 MP3 player?
is that mp3 player have the facility to add memmory card... then see in the side of the player their will an space given to insert that mcardf
Sep 02, 2009 | SanDisk Sansa c240 MP3 Player
Sansa c240 will not load chip
I used a 4gb micro chip and everything works fine. NO MORE PROBLEM>>>>>>
Feb 10, 2009 | SanDisk Sansa c240 MP3 Player
My sansa c240 is always freeze
hey u keep pressing the on/off button for a while then again insert ur sansa in usb port of ur comp ... it started working for me after that !!!
Feb 07, 2009 | SanDisk Sansa c240 MP3 Player
SANSA c240 fails booting
i want softwere of sansa c240
Jul 08, 2008 | SanDisk Sansa c240 MP3 Player
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
My sansa M240 WonT turn on all the way
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa c240 MP3 Player
Sansa c240 isn't being recognized by the computer...but...
-Tha Mp3 Doctor
Mar 23, 2008 | SanDisk Sansa c240 MP3 Player
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
SanDisk Sansa c240 MP3 Player Logo
402 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
