Question about HP Color LaserJet 2600n Printer
Margin printing problems
Hi, I've created a tri-fold brochure but my printer (HP deskjet 940c) cuts off the right side of my brochure. I've tried changing the margins and even downloaded a template that goes to the very edges of my paper, but it still cuts it off. Please help me resolve this issue. Thank you - Sue
  • Anonymous Mar 30, 2014
    the printer cuts off 1/2" on right side of paper but used to print to edge
    Novelist:
    Scholar:
  • 167 Answers
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Posted on Oct 09, 2007
SOURCE:
Hp deskjet 940c does not print, blank paper goes thrugh. Computer conction is right, ink ok ( not flushing lights) and clean.
Hi you need a new black ink. it may be empty or faulty.
The machine dos not measure the amount of ink in the tank it only counts the amount of squirts you have used normally its only a problem with refiled inks
if this is useful please rate me thanks Ian
Mar 08, 2011 | HP DeskJet 940c InkJet Printer
HP Deskjet 5650 is printing off-center. The printing field is shifted to the right, so the right margin is non-existent and I lose a bit of the printing. How can I fix it?
I think the horizontal printing starting point can be adjusted by holding down buttons (??) when powering up. Right now my left margin is 3/8 inch too big -- photos have that much white space on left margin with borderless printing. I am trying to figure out the key combination.
Jul 27, 2010 | HP DeskJet 5650 InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
How do you check the ink levels of the cartridges on a hp deskjet 940c
If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
Thanks
Shereena.
Apr 22, 2010 | HP DeskJet 940c InkJet Printer
Printing Legal size brochure (landscape) that gets cut off
readjust the margins in the printer page set up just before printing
Sep 08, 2017 | HP Inkjet 1200D Printer
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Bottom of page is cut off sometimes printing from vista computer
Hi- I'll try to solve this.
Go to the start menu and open the Control Panel. Double click on Printers. Right click the L7580 printer and choose "Printing Preferences" On the preferences window click on the "Advanced" tab. Make sure "Advanced Printing Features" is set to "Enabled" Under "Printer Features" turn "Minimize Margins" to "On"
This should solve the issue. If minimize margins is off, it will cut it off at the bottom.
Feb 06, 2009 | HP Officejet Pro L7680 All-In-One Printer
Hp deskjet 940c printer
Hi.
I think it must be the ink blow-by, you must clear the ink path through the printer head. Try to activate the cleaning of the head pins. Just go to the printer icon then right click and click the printing preferences then look for the head cleaning menu. then try to print test by doing a cold reset.
Jan 24, 2009 | HP DeskJet 940c InkJet Printer
Left margin of text is cut off
Check your margin settings in your printer set up.
Jan 09, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
912 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
