Question about Gateway FPD2275W LCD Monitor
Princeton 17" LCD Monitor
Monitor won't stay on. When I turn the unit on it the picture will flash on for aboue 20 seconds then goes off. Repeatedly turning the unit off and on gets the same response. BUT sometimes it works just find. Have replaced the video card - no change. Once of the solutions talked about replacing a light/lamp(?) where, how, etc. I have taken it to a repair place and, of course, it went on just fine then. Can it be a bad on/off switch? And, if so how does it get replaced?
  • annamaybell Oct 09, 2007
    This monitor has been working for a couple of years on the same PC.
  • connolly Feb 05, 2008
    Was this a new monitor installed on your pc or did it work at one time on this same pc?
    Yes! this a new monitor installed on my pc!
It is a component problem on one of the PCB printed circuit boards in your unit. Probably the Invertor or power board or power inverter or what ever its called. It is a common problem that there is a component like a capacitor or transistor or diode that goes bad and will need replacement. See this URL as an example. I understand it is not your make or model but it is the same symptoms.
http://ezinearticles.com/?How-to-Repair-Dell-E151FP-LCD-Monitor&id=222546
OR similar but not the same (this might shed some light)
http://www.instructables.com/id/EL0W35Y7L7EQZJIZSL/
I have repaired this dell lcd using these instructions
Posted on Jan 19, 2008
    Problem Solver:
  • 8 Answers
Have you checked you video drivers? you may try annother monitor to check your computer for a video DRIVER type problem/incompatability. Was this a new monitor installed on your pc or did it work at one time on this same pc?
Posted on Oct 09, 2007
SOURCE:
I have a 17 inch princeton monitor and the screen goes off frequently. each time it was every 15 mintuires now it goes off every 4 to 5 mintures. i turn if off and back on and it works. help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | Princeton Digital VL1716 17" LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
I have a 20 sceptre widescreen lcd monitor
Have you tried any other monitor connected to your computer since your current problem? Check your connections, make sure your VGA cable/DVI cable are in good condition. If none of that works try to RMA it to sceptre if your still within the 1 year period.
Apr 07, 2009 | Sceptre X20g-Naga III 20.1" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Goes out
Please list the model number of your monitor.
Also is the power light flashing? What color(s)?
Unfortunately the symptoms you are describing tell me the inverter/power board inside your monitor needs to be replaced.
Mar 05, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Princeton VL1919 repeatedly pops when turned on
If you feel confident take the monitor back cover off and replace the 3 bulged out capacitors
Jan 26, 2008 | Princeton Digital VL1916 19" LCD Monitor
Monitor only stays on for 3 seconds
There is probably a bad capacitor within the monitor that will not allow the picture to "hold" in the on configuration. This will need to be replaced. You can send it back to Phillips, or 17" monitors are pretty cheap these days. I would suggest a Samsung or BenQ. They both carry 3yr warranties.
Aug 17, 2007 | Philips 170S4FB 17" LCD Monitor
My monitor says "input ......" and then the screen flashes off.
This is a duplicate post, click the following link to read the active posting: http://www.fixya.com/support/t138012-sony_sdm_hs74p_s_17_monitor_stay_right
Mar 16, 2007 | Sony SDM-HS74P/S 17" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
50 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
