Question about Nintendo DS Lite Crimson & Black Console
PS2 wont read disks
My ps 2 boots but wont read disks. ive tried cleaning the lens. any ideas would be appreciated
  • Wort Oct 20, 2007
    already sent it for repair - yep probably the laser
  • Anonymous Jan 15, 2008
    i have the same problem and it is reall tickin me off
    Problem Solver:
  • 19 Answers
The same thing happened to me, but it only wont read the black / blue backed discs (that were made for ps2) ps1 games worked fine... does anyone know why?
Posted on Sep 01, 2009
Same thing happened to mine, is it the older fatter ps2? because the one i had just kinda crapped out on me. your best bet is to buy a slim one or send it in to get fixed.
Posted on Jun 22, 2009
    Problem Solver:
  • 15 Answers
Better ask a repairman maybe it is time for you to replace the lens itself
Posted on Oct 20, 2007
SOURCE:
Ps 2 wont read game disc, goes straight to browser setup.
Your PS2 lens is probably weak or its dirty.You should try to clean your PS2 lens first.A dirt on lens wont let your PS2 lens to read your Game disc. Watch this video this will help you to know how to clean your PS2 Disc Reading Lens.
Try to place your PS2 at clean place and clean your PS2 regularly.
Nov 30, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
its either a dirty lens inside the drive or a dirty disk. start with trying a lens cleaner.
Jun 12, 2008 | Sony PlayStation 2 (PS2) Console
Why my ps2 not play games only play video,But Before My Ps2 Play Video And games too, what is my ps2 problum plz help, my emai: [email protected] thanks
When your console does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the PS start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the PS, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
before doing tis, contact Sony to check if the unit can be replaced or repaired by Sony, you find the number on the Console documentation.
Sep 18, 2009 | Capcom Video Game Consoles & Games
My PS2 wont read any disk.
HI, the optics assembly has failed. the actual optical lens assembly will need to be replace in this case. you can try to clean the lens with a cleaning disk.. this may wake the laser. if the cleaning doesn't produce results, replacing the optical lens assembly will be the next move.
Jul 21, 2009 | Sony PlayStation 2 Slimline Console
Ps2 format disc
Dirty laser / or a damaged disk.
Open it up and use a Q-tip soked in windex
wipe , then try it again should fix the red screen of death.
Jun 04, 2009 | Sony PlayStation 2 Slimline Console
Playstation 2 slim
you might want to get a long q-tip and gently put alcohol on it and swap the lens.then have another tip ready to dry off. ps2 games are basiclly a dvd . and you can find info about a lawsuit that sony has against them for not being able to read dvd's.
Jul 19, 2008 | Sony PlayStation 2 (PS2) Console
Disk read
This may be caused by the discs you are trying to read are Dual-Layer format DVD's. Your best bet would be to get in contact with Sony.
Dec 30, 2007 | Sony PlayStation 2 (PS2) Console
Playstation 2 problem
I would try cleaning your Playstation games, Check and make sure that the games your trying to play are not cracked in anyway. Also, if you have your system standing vertically lay it down horizontally. Many times after you've closed the disk in it lens to far away from the lens.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
PS 2 says no disk tried to put alternate disks but problem still persist
Your Laser is not seeing the Disc. Several reasons could be as follows:
  • Dirty lens on the laser
  • Bad ribbon cable not supplying power or reading the Laser.
  • Major misalignment of the laser
  • Motherboard Laser Driver IC burned up.
Alrighty then, you probably see now that when you get a no disc error, the fault is 99% related to the laser.
You have to clean it up and get all the dust out. Do not use alcohol on the Slim PS2 Laser. Use a q-tip dampened with rubbing alcohol to clean the lens. Dry the lens before you try it..
Dec 19, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 wont read discs
i can only think of two things with that problem. one your lens might be scratched or the laser unit is no good. you can replace that part by removing it from an older unit or going on ebay buy it from them unit model SONY PS2 SPU3170 Laser 3170 Lens. this will solve your problem fast.
Dec 03, 2007 | Sony PlayStation 2 Slimline Console
Nintendo DS Lite Crimson & Black Console Logo
111 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
