Question about Dual XDVD8181 Car Video Player
Cd insertion won't accept cds more than halfway anymore, where in particular can i get it fixed
  • 4 Answers
I have two 8182s that both do this. Got fed up and took them apart. Both of them had a broken hinge pin in the back of the cd/dvd drive. There is a fairly strong spring that clamps the disk once it get inserted and I believe the tension on the spring is causing the hinge pin to break out of the plastic it is mounted in.
I epoxied mine and put a lighter spring in and so far it is holding up. Good luck if you are not VERY tech oriented. This isn't designed to come apart easily. Wish I could bring everyone some better news but I think it is a design flaw of the units.
Scott
Posted on Jan 05, 2008
SOURCE:
My Acer Aspire 7540 DVD Super Multi DL drive suddenly won't accept DVD's anymore
I ran into the same problem and found a program on www.download.com Type dvd repair, this program will fix most issues and worth saving on a flash drive, or hard drive for future repairs.
Jun 20, 2012 | Computers & Internet
RCA rs2130i won't play MP3 or WMA anymore
first the laser may be dirty. you can find lens cleaning disks at any cd store. But have you recently bought a new pack of cds? Sometimes certain CDs just simply dont work with some players. No reason for it they jsut dont work. You could also be using the wrong type of cd, CD+R vs CD-R
Feb 06, 2012 | RCA RS2130i Shelf System
CD/DVD Drive won't accept new blank CDs and they jam in the computer. I have to restart the computer (sometimes more than once) to get the machine to eject the discs.
The problem would be the dvd rom, it won't read anymore. That's a problem with a combo DVD rom, when it being use frequently it tends to breakdown, mainly the problem is the internal parts. I have tried repairing most DVD/CD Roms, to no avail..... mostly the problem would be the parts, and it is not available in the market, and it is better to buy a new one than getting it into the manufacturer's service center, they charge excessively like your buying a new one!
If the CD is stuck inside, get a pointed metal rod, there is a small hole in the face front and push the rod into that hole untill it opens the cd tray.
Thanks for using FixYa!
Jul 04, 2011 | Apple 20" iMac Desktop
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
Jun 23, 2011 | Dell Inspiron 6000 Notebook
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
Xplod cd player reads Err 99 and wont accept cd
I had the same problem.
i fix it by taking out the cd player and pulling the outer case off. when i looked inside and the (in technical terms) metal bracket that holds the white plastic disc (that i guess holds the cds) inside the cd player was bent down. i am assuming that cds were hitting this when i tried to insert them! i just bent it back up using a knife from the outside. i bent it up until the white disc looked level.
good luck
May 16, 2009 | Sony Car Audio & Video
M&S CD Player keeps ejecting all cd inserted into player
if you are using good,new,cd,r and no accept try to do this in a room with no light put in operacion the cd player see what happens......if the same time to change for a newone or sendit to repair shop
Nov 16, 2008 | Audio Players & Recorders
Dual XDVD8181 Car Video Player Logo
95 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
