Question about Dryers
Maytag Gas Dryer MDG3000AWW
I have a Neptune gas dryer. It will light up, but only stays lit for 5-10 seconds. The dryer is still running and I hear a click sound like it is wanting to light again but doesn't. If I stop the dryer, then push the start button, it will light again for the 5-10 seconds. Any idea what part is malfunctioning?
  • 1 more comment
  • Railprosue Oct 09, 2007
    All the connections seem to be secure. I have cleaned all the dust off. When it lights, the gass flame stays on from 5-20 seconds. How long should the flame stay lit?
    How do I check the thermostat? I do not have a web cam.
    I found the thermostat and will get a new one tomorrow and try it. Is there any way to tell it is bad before I purchase a new one?
    Also, HOW LONG is the gas flame supposed to be ignited?
  • 790 Answers
You check all the wirings maybe you have lost contact wirings!
Posted on Oct 09, 2007
  • 2 more comments
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 09, 2007
    did you check the thermostat?
    or sir mam! i wana see your unit in livecam to give you an better instruction!
    maybe your thermostat is defective! you can see the thermostat at the under of the gas flame! a small circular ceramic with metal inside the hole!
    its depend in the rating in the thermostat, the rating is indicated at the thermostat! what how long to ignite! i hope you rate me as solved!
2 Suggested Answers
  • 4 Answers
SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Posted on Jan 10, 2008
Mdg3000aww gas dryer. drum turns. ignitor glows and goes off but no flame.
I suppose you made sure the gas is on. The valve probably has two valve coils sitting on top; one is a dual coil. My guess is that one coil is "open" (no continuity).
Sep 07, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Sep 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MDG3000AWW Maytag Neptune Dryer. Not heating correctly
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 02, 2010 | Dryers
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Gas will not stay lit.
sounds like a bad coil
they are on top of the gas valve
Jul 03, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer runs, doesn't dry
Check in the hole where the screen goes for blockage. Many times debries falls in there when removing screen. It cant make it out of the vent so it builds up and clogs the vent.
Dec 01, 2008 | Maytag Neptune MCG8000AW Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Oct 08, 2007 | Dryers
Dryers Logo
204 people viewed this question
Top Dryers Experts
