Check to make sure that both computers have the same socket type, it should be printed directly on the connection for the processor. If the sockets match, you should have no problems dropping the new processor in it. Incompatible processors simply won't fit in the motherboard, so if you can't seem to get the processor to fit properly, it's most like incompatible.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Intel Celeron D 355, 3.33 GHz
select the decimal written correctly in expanded form 4.9? select the correct place value for the...
(More)
SELECT THE DECIMAL WRITTEN CORRECTLY IN EXPANDED FORM 4.9? SELECT THE CORRECT PLACE VALUE FOR THE UNDERLINED NUMBER 0.0006_ 6 IS UNDERLINED? SELECT THE # that is written as a fraction correctly 34.5 1.448? select the # that is written in digits correctly one hundred and four hundredths?select the number that is written as a decimal correctly 9-10 and 3 45/100? thirteen thousandths in decimal form ? select the # that is written in words correctly 0.009 and 53.106?23.07 # written in words correctly?select the decimal written correctly in expanded form 1.06?select the # that is written in digits correctly six and four tenths?select the correct place value 1,034.22_11
