Question about Samsung Cell Phones
Sim Unlock Codes - Samsung Cell Phones
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
Sep 29, 2016 | LG Cell Phones
How can i unlock my sim card? here is my imei code i cant unlock my sim card
Your IMEI number is your phone's identity, much like your social security number. On the other hand, your PIN number is a password to access and activate your SIM card. That means, your IMEI will not help to unlock your SIM card.
To unlock your SIM, you will need your PUK, PIN2 or PUK codes. These codes are printed to a page which is typically delivered to you when you receive your SIM card.
Assuming that you cannot find your PUK, PUK2 and PIN2 codes, I believe the safest and the easiest way to unlock your SIM card would be
  1. to call the customer support (would be better if you call from your landline)
  2. to visit your mobile carrier's nearest shop/kiosk and ask for assistance
Regards,
Tolga
Jul 30, 2014 | Blu Studio 5.0 Mobile Phone
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
Jun 06, 2014 | Samsung Galaxy S GTI9000 Smartphone
Sim network unlock pin
SmartphoneUnlockers provides unlock codes to network unlock devices. This will help you use your device with other SIM cards, even international carriers!
Apr 17, 2013 | HTC Sensation 4G
How do i find unlock sim codes, pin codes, and password codes for free
hi you can get the sim unlock codes for your motorola razr from this site wickedunlock here they ask the network name to which your mobile is locked then the imei number of the mobile finally they will send you the sim unlock codes .
Nov 16, 2011 | Motorola RAZR Cell Phones
When ever i insert a sim card in my nokia phone it tell me invalid sim i want to know why, and the solution to it
Have you tried to insert your SIM in a contracted mobile? is you try to insert your SIM in contracted mobile,it will not allow any other SIM...so to get rid of this problem you have to unlock your mobile by unlock codes...for unlock codes you can contact your provider or can get it from online providers..what is your mobile model? if its basic model then try getting unlock codes from unlock-free to get unlock codes for free by just submitting your mobile's imei number and get unlock codes to unlock your mobile..if your mobile is of recent model then try with unlocking4u and get codes and unlock your mobile..
Sep 06, 2011 | Cell Phones
Sim lock
i cant get your question clear. whether your phone is locked to your sim or your sim locked?if you phone is locked to your sim you can unlock it. in such case there are many ways to unlock a phone. you can unlock it using software or hardware or through codes. if you ask me the codes are the best way to unlock it. unlocking through codes is the best and simple way to unlock any phone. i got my phone unlocked through this method only. you can get the codes either from your service provider or from any other service providers. getting codes from your service provider can be got only if your phone is within 6 months of the contract period.. i got the codes from a third party Classicunlocking.com provider. they also provide codes even for older model phones.
or if your sim is locked you need to flash your sim.
Sep 03, 2011 | matsumo My SoftBank Checker
HOW DO YOU UNLOCK SIM PIN IF YOU DO NOT HAVE THE CODE? I GOT THIS PHONE THE SGH-I617 AND WHEN I PUT MY SIM CARD IN IT IT SAYS THIS PHONE CAN ONLY BE USED WITH A SPECIFIC SIM. ENTER THE UNLOCK COED OR...
It means that your mobile is locked to particular network,to use other provider's sim you have to unlock your mobile..you can try it by unlock codes and unlock your mobile..once i got unlock codes from theunlockspot and unlocked my mobile,you can too try getting codes for your mobile and get it unlocked..
Jul 31, 2011 | Samsung SYNC SGH-A707 Cellular Phone
Unlock or subsidy code
http://reviews.ebay.com/FREE-SIM-UNLOCK-CODES-DONT-BID-ON-SIM-UNLOCK-LISTINGS_W0QQugidZ10000000001870681
This should work for you.
Mar 29, 2008 | Cell Phones
Cell Phones Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
