Is my t.v dead???
I think my t.v has died this mornin',the sound is good but the picture shows just a bar across the bottom of the screen. Bad picture tube??
  • angeloem Sep 03, 2008
    my tv not work is dead
    Champion:
  • 225 Answers
No, not atall may be vertical section problem, check vertical sction crcuit, check all the capacitor and ics at vrtical section .../
Posted on Oct 09, 2007
If there is a wide faded vertical line that is showing on the screen and a black film that shows up periodically across the screen. Does that mean that the picture screen need to be replaced?
Picture tubes are one of the last components to actually die in any CRT television. Usually the only reason they are / were changed was due to colour degradation or dead pixels. I would be looking at either the colour boards or for yoke damage. If the picture still fills the entire screen then the high voltage section and tube are still OK.
Hope this helps a bit. Cheers Bob
Nov 17, 2016 | Televison & Video
My Samsung HL56A650 turns on, but no picture. We were watching it, and the picture just quit. When you turn it on now, the power recycles several times then all you get are 5 or 6 thin horizontal lines...
Now ur tv still get a solid power LED light?Yes,only few colors strip lines show up,mean ur tv board that call the T-CON decoders board is dead.This T-CON decoders board sit in the niddle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Jan 23, 2011 | Samsung HL56A650 56 in. TV
My large screen projector type tv has a picture but there is groups of lined running across the screen from top to bottom. audio fine.
Sounds like hum bars if there white bars.Try disconnecting the ground outside at your cable hookups or sat etc.
Sep 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Jul 20, 2009 | Canon ZR80 Mini DV Digital Camcorder
Potentially dead Nintendo DS lite LCD screen. (bottom)
Hey, I can help you.
Yes, the Bottom LCD is dead. You will have to exchange it.
Below I have two links you should follow through. One to purchase a bottom LCD for a very cheap price and the other will show you how to replace the bottom LCD.
REMEMBER.. To place a plastic pad under the bottom lcd so it doesn't ground out the board. Forgetting to do this could potentially blow a fuse and you will have to replace those!!
1.) http://www.amazon.com/dp/B000RWXCE2?tag=wit08-20&camp=14573&creative=327641&linkCode=as1&creativeASIN=B000RWXCE2&adid=0JJ799NSS5VV0XTY8DYK&
2.) http://www.instructables.com/id/S3ZZJPKFA0CVIFO/
May 27, 2009 | Nintendo DS Lite
Horizontal color line across the screen
Most likely a bad Vertical IC or bad connections on the vertical IC. don't continue trying it on. If you have a bad connection it could do more damage. You also could damage the CRT ( picture tube ). If you remove the cover and look at the bottom side of the PC bord with a good magnifiing glass you may see what looks like rings around the leads comming from the Vertical IC. The Vertical IC is mounted on a heat sink usually towards the front of the set looking from back. If you do see the rings around the leads try reheating with a solder iron. If this dosen't fix you most likely need a new IC.
Apr 15, 2009 | Televison & Video
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Thin line across screen
Sounds like cold solder joints in the vertical circuit and also check around the yoke plug.
Apr 04, 2008 | Televison & Video
Missing bottom 1/4" of screen
It is possible that you have zoomed in your picture inadvertantly. Try going to picture settings and making sure that you are zoomed out all the way.
Hope that helps!
Dec 30, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
