Question about ECM Giotto Espresso Machine
How full should a reservoir tank should be - ECM Giotto Espresso Machine
Low coolant light stays on until system heats
Your overflow tank(aka coolant recovery reservoir) is low on coolant. The coolant expands when warm and raises the level in the tank, which turns off your light. Top off the reservoir (when cool) to the "Full Cold" line. If you have to keep adding on a regular basis, then you have a leak somewhere in your cooling system, could even be the reservoir itself.
Oct 18, 2015 | 2000 Buick Century
If the reservoir tank is filled with coolant, it is necessary also to fill up the radiator with water or coolant?
Depends. Not usually because as engine heats and then cools when shutoff, reservoir should allow radiator to suck back what it needs. However, if you have just flushed system, or replaced water pump, you should fill at radiator as well. Bad radiator cap that prevents backflow can cause problems as well.
Jun 05, 2015 | Hyundai Accent Cars & Trucks
Windshieldliquid show add but its full
it probably has a calcium buildup in the tank. I have worked on so many different types of vehicles, so I can't recall the exact location of the reservoir but, if it is at the bottom of the vehicle the whole front underside panel between the bumper and the frame will need to come of just to get to the tank. you will need to light ly knock on the sensor area on the tank to help the float back up. Add a little lime away to the reservoir, clean the tank out, it probably has a lot of buildup.
May 25, 2014 | 2010 Buick Lucerne CXL
The antifreeze is not staying in the car but it is still in the resovore and the car is not over heating (thank goodness)
You should have antifreeze in the reservoir that is the over flow tank the radiator will stay full the excess will go into the reservoir tank that is normal. And it will pull it out as needed from the tank.
May 19, 2013 | Cars & Trucks
Car keeps saying stop check coolant, and service manual. The coolant fluid level is full.
all you have to do is remove the three screws to the the coolant reservoir tank {drivers side} it should say g12 on it.Disconnect both hoses and the sensor from bottom of tank .Have a rag handy and perhaps a small jar to catch the small amount of coolant that will squirt from the hoses. Also remove the coolant from the reservoir and put in a clean container so you can put it back in the reservoir when your done. Take the coolant tank to your "garden hose" and flush it full blast. It works better if you leave the cap on.But you can take on and off and shake it repeatedly until you have thoroughly rinsed it.--NOTE the sensor is located in the bottom of the reservoir and over time gets clogged. You can even try soaking it in a de greaser and then the "garden hose" process. Then replace everything and attach all hoses and sensor and refill reservoir with the coolant that you put aside in the container.Start the car..This is the only thing that got my light to go off.
Mar 22, 2010 | 2003 Volkswagen Passat
Ink colour print problems
Ink that leaks out of the ink-cartridge when the print-heads are "parked" is absorbed into the "reservoir" tank. The tank is full. Get it emptied.
Sep 14, 2009 | Canon i9100 InkJet Photo Printer
FUEL PUMP 03 PONIAC GRAND AM HOW TO INSTALL
is your pump visible or is it in your fuel tank? if it is in de tank you need to disassemble, bring down tank.
Sep 04, 2009 | 2003 Pontiac Grand Am
Printer message, ''out of ink'', ink tank half full.
Nope....the sensor looks at the reservoir. replace your ink
Mar 25, 2009 | Canon Office Equipment & Supplies
Reservoir empty tank lights up but tank is half full of water
in the water tank you have a little magnet that magnet need to move up and down shake the water container to see that magnet move .thanks for using fixya
pierre
Feb 26, 2008 | Saeco Magic De Luxe Espresso Machine
ECM Giotto Espresso Machine Logo
13 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
