Question about Dell Latitude C640 Notebook
Latitude D510 When I start my computer it powers up then immediately turns off. I get nothing on the LSD screen but see the power lights light up. This takes about 15 seconds.
  • floormall Oct 09, 2007
    Memory issue. Memory stick fell out and caused issue. Thanks.
    Scholar:
  • 181 Answers
Try re-seating your memory. If you have two sticks in, take one out and try each one in each slot. Also, try to connect an external monitor and see if you get anything. It has to be hooked up before you boot. Good luck
Posted on Oct 09, 2007
G62 won't boot up
Take out the battery and wait a minute, then put it back and try again.
Mar 03, 2017 | HEWLETT-PACKARD HP Laptop / AMD Turion II...
Laptop power light comes on , fan starts then laptop shuts off
Laptops (and PCs) have sensors to kill the power when overheating takes place, particularly the CPU. You should take it to a local repair shop and let them look at it for you
Oct 03, 2017 | Acer Genuine Aspire 5250 5333 5733 5733z...
Just done an bios upgrade everything went fine but guess what yes it went wrong the computer shut down yellow light in the upper right hand corner stayed on charging light was also on nothing on screen...
take off : power cable , battery wait 5 min
open the case take off the c-mos battery , wait 5 min
mout everything , start the machine again , whit all connections , so you did a reset from your bios
Apr 18, 2017 | Acer Aspire One AOA110-1113 Netbook
I started setting up an intel d865perl today and i'm pretty sure i did everything right, i followed diagrams read manuals and such but when i plug in the power cord it immediately starts and there a green...
1. There is a BIOS SETUP setting to "automatically start after a power outage" -- this is useful for "servers".
2. If you press and HOLD the power-button for TEN seconds, the computer should shut itself off.
3. Turn the computer off, disconnect the "data" cable to the HDD (hard-disk-drive) and then turn the computer on. Does the HDD lamp still light-up?
4. Do you get any on-screen video when it starts to start-up?
Sep 02, 2010 | Intel D865PERL Motherboard
Wont boot/start
Turn off power, unplug, hold power button for 30 seconds, take out memory, or if you have more than one stick only take all but 1, plug the power back in and start the computer. If a screen pops up that bios has changed press F2 to continue once computer is completly loaded click start, shut sown, unplug power cord again, hold power button 30 seconds, insert other memory and restart
May 13, 2009 | E-Machines eMachines Desktop PC
My biewsonic va702b, when powered up flashes for one second the screen. it's bright in all the corners, just wont stay on, power light changed to orange. do I have inverter problems??
The power light turning orange means the monitor isn't getting a signal from the computer. Or the monitor has a problem. If the screen shows light in the corners, the inverter is working. (If the inverter stops there is no light at all.)
The first thing to try is connecting another monitor to make sure your computer is actually starting up. If that monitor also shows nothing, you have a computer issue to take care of. Otherwise the monitor needs service.
Mar 03, 2009 | ViewSonic VA702B 17" LCD
Polaroid tv w/ black screen
hi..then there is a problem in your smps
power supply.If you have the warrenty period
take it immediately.
check it out..
thank u..
rate me..
Feb 28, 2009 | Polaroid FLM-3732 Television
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Monitor light blinks
have you tested the power supply connection feeds? test each connector I think you will find your power supply has failed on either the 5 volt or the 12 volt side more than likely 5 volts are down' the agp adapter needs 5 volts to run. since you have changed out every thing else I would replace that or test your dads power supply in your computer, that should do the trick
Apr 28, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Dell Latitude C640 Notebook Logo
63 people viewed this question
Alun Cox
