Question about Panasonic PT-47WX49 47" Rear Projection Television
Uh oh... the colors are curved and wacky
It looks like the three color guns (if that's what they are) have gone haywire. It was working okay, then suddenly the green, red and blue are curving in different directions. I tried the alignment setup but it doesn't work, because the problem isn't uniform throughout the screen; I've got a bulge in the lower left where the green curves upward, with the red and blue curving less so. They're also curving across the top. The only place the picture is fine is in the middle. Bottom left two-thirds have a big red swath, with graphics appearing double and triple. Is there any hope for fixing this, or should I just figure it's been a good 9 years and scrap it?
  • 5 more comments
  • djkr Nov 05, 2007
    My TV is starting to show double letters and rainbow colors at the bottom of the screen. Can I fix this with the remote or will I have to have it worked on?
  • jkropog Nov 23, 2007
    Yes I have the same curvy lines. Something happened. I saw the suggestion for a new amplifier IC chip. Has anyone tried this and did it work??
  • Anonymous Nov 26, 2007
    Having the same problem, the blue gun has shifted to the left. Is there any hope.
  • ozzyal Nov 28, 2007
    Yeah, I got the same problem, the red is making the picture look double, I tried to alling them, but only one didn't allign (#4). What can I do.
  • jamfish7 Aug 27, 2008
    I have read many needing help with this and only one 'possible' solution... has anyone fixed this problem successfully?
    Thanks
    Jfish
  • biglife Sep 28, 2008
    How much will it cost for me to get this fixed and who should I contact? My tv just started doing this the other day. It is 5 years old and the Mgr. @ Circuit City told me it would cost $150 just to have someone come here and look at it. Help!
  • Anonymous Sep 29, 2008
    I have the exact same concern with a pt-47wx52. Anyone have a fix?
Replace the amplifier IC chips for the convergence.  part # stk392-???  could be from 040 to 120..  90% chance that'll fix it.
Posted on Oct 20, 2007
SOURCE:
My dell 1201 projectors displays only in yellow
you have most likely lost 2 of your color guns, most projectors have RED, Green and BLUE as the projector colors (some newer projectors have added a 4th color). if one of your color guns has gone out, you may experience colors that are not correct. that is where I would start. go to the convergence routine, in your setup menu. this is where you can determine if one of your "guns" has quit working.
Mar 23, 2011 | Dell 1201MP Projector
To much red color and very little green or none at all
you may have a dead or bad color gun. go thorough the convergence routine and see if all the colors are there. If your missing a color, you can purchase just that gun but I would advice that your replace all three. Be aware that this can be costly and in some cases you may have to purchase the whole pc board with the three color guns on it, depends on the model.
Mar 16, 2011 | Hitachi 43FDX15B 43" Rear Projection...
My Akai projection tv the color has bad color and double vision. Why?
If you have an older model projection set then the Convergence Ic's have gone bad. This type of repair usually cost around $250.00 to repair and can be done in the home by a technician.
Dec 27, 2010 | Akai Televison & Video
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
No red color in my Hitachi TV
there are three guns that produce color
red blue yellow they make the spectrum which includes black if one of the guns burn out you loose that color if the gun is good then the color board that controls that color is bad
Feb 26, 2010 | Televison & Video
JVC AV-56WP74 Colors quit working or went out of balance.
Guns or CRT are probably ok. Your TV needs a convergence IC STK392-120 replacement. Lamp are used on LCD and DLP rear projection TV's. Color wheel are for DLP's. :)
Dec 26, 2009 | JVC Televison & Video
Loss of color when watching dvds
Uh oh, time for a shop visit as the chroma processor is not working properly....accordianman
Jul 03, 2008 | GoVideo DV2150 DVD Player/VCR
KP51ws500 turns green and shuts itslelf off
There may be several causes but, one is that when any color gun is being over driven, the Sony shuts down the gun to protect it. Try this. Remove the front of the set by removing the two screws from each lower corner. Next remove the black panel held on by 5 or 6 screws. Now you should see a panel with 6 potentiometers on it. Turning the ones on the bottom row CCW reduces the drive. Turn the color down and if all the guns stay lit, SLOWLY turn them up until you get the color balance that you like.
May 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Poor color
I am about to say something that may sound stupid but it sounds like you are experiencing this. After years of use you CRT guns in your case the gun in each one of your CRTs(RGB) begins to oxidize and decrease in its ability to provide electrons for the scaning beam this creates a dark picture. Common problem? yes, over time, but for it to happen in just six years is strange but it can. Major Problem to have repaired? No, the technician will use a CRT rejuvenator on all three of your guns and then balance them and you are off and running. Now the other problem that might be occuring low CRT anode voltage. this could happen. Common problem? yes, it is the best choice Major Problem to have repaired? yes and no depending on which components are bad.
Sep 20, 2007 | Hitachi 43FDX01B TV
Panasonic PT-47WX49 47" Rear Projection Television Logo
266 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
