HP Compaq nc6120 PC Notebook
Problem for HP Compaq nc6120 PC Notebook
Wireless and bluetooth won't turn on
By p4r4n01d on May 06, 2009
i actually have 2 nc6120 notebooks, one works perfectly, the other refuses to allow its wireless and bluetooth to be turned on (normally done by a button near the screen)
so far, i have tried swapping the harddrives, thinking maybe a driver problem. i have tried swapping the button panels that have the wireless button on them, thinking maybe the button or chip was faulty. and i have tried swapping the wireless mini pci cards.
but no success. the problem stayed with the motherboard each time
i also checked the cmos setup and the wlan card and bluetooth are both enabled there
this isn't the first time i've encountered this problem, i have another nc6120 and an nc8430 with the exact same problem
any help would be greatly appreciated
Comments:
May 06, 2009
- i've already tried putting a perfectly working nc6120 hdd into it (swapped from a working machine) to no avail
May 06, 2009
- the device manager in both machines (working and not working) matched exactly, except for the bluetooth (which is disabled in the non working machine)
May 06, 2009
- all other devices seem to work fine, no problems in device manager
just tried without the battery and same story
May 06, 2009
- palaboy do you mean the mac addresses? yes, they are different
May 06, 2009
- they are both set to automatically obtain an ip address, but my problem isnt connecting to my network, my problem is that the wireless and bluetooth are essentially disabled. (the laptop doesnt see the hardware)
May 06, 2009
- the device is already enabled in device manager, i also tried disabling and re-enabling it.
safe mode also doesnt work
theres a led on the wireless button that is on when the wireless is enabled.
on the laptop that works, that light can be switched on and off before the OS even loads (even from cmos setup).
on the laptop that doesnt work, it doesnt come on at all.
this tells me it isnt a driver or windows problem
May 06, 2009
- warranty expired in feb
May 07, 2009
- already checked the bluetooth and wireless are enabled in bios
and adding a usb network card defeats the purpose, as i am trying to fix it for resale
May 07, 2009
- if anything apart from the wireless card is preventing it from getting on the network, it would be a software problem that would have been resolved when i swapped the hard drive with one from my fully functioning unit (which is still fully functioning and connecting to the network despite having the other unit's hdd)
May 07, 2009
- also, i can connect to the network using the ethernet port
May 08, 2009
- tried flashing the bios with the latest update, still no effect. i agree that it probably is a motherboard or connector issue
Best Solution
posted on May 06, 2009
Helpful)
fabioxx
Rank: Guru  HP Computers & Networking  Expert
Rating: 85%, 146 votes
Try to uninstall and reinstall the wireless and bluetooth software.
If all fails try a windows repair install.
Comments:
May 06, 2009
- what other devices are connected to the computer that doesn't work?
Does it happen with the battery and without the battery?
It's somehow pointing to a bad motherboard.
May 06, 2009
- If you try to enable the device in device manager does it enable ?
Try it in Safe Mode also.
May 06, 2009
- Does it still have warranty?
looks like it might be the connectors on the motherboard that are conflicting or failing.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
palaboy
Rank: Wiz  HP Computers & Networking  Expert
Rating: 83%, 1308 votes
have you check the properties in the device manager?
Comments:
May 06, 2009
- verify the networking address on each , it should not be the same
May 06, 2009
- check also the ip address
May 06, 2009
- try viewing the log on your router to see whats going on
May 06, 2009
- try also enabling it in bios configuration
May 06, 2009
- try adding usb network card instead
May 07, 2009
- and we are trying our best to help you, without testing an added usb network card how will we know that it can connect to internet? i think thats the sole purpose of your inquiry, if ever i will be buying your stuff first thing i would ask is can it connect to internet?, what i am trying to establish here is your laptop to be connected to internet, we have to find solution for your very nice laptop, and if youre not satisfied with my solutions then i dont have anything more to say to you.
Was this helpful?
Yes
No
Solution #3
posted on Jul 29, 2009
Not Rated)
That IT Guy
Rank: Apprentice
Rating: 95%, 5 votes
To kickstart the wireless and make it work again on the nc6120's.
Turn on the computer and hit F10 to go into the BIOS.
Go up under File and choose Restore Defaults.
Save your changes and reboot your OS.
If your using Windows, you should be able to pick a wireless network now.
If you previously had a WEP or WPA pw key set, you may have to re-enter
it again as it was cleared out during the reset.
Was this helpful?
Yes
No
Solution #4
posted on Jul 14, 2009
Not Rated)
wstiggins
Rank: Apprentice
Rating: 0%, 0 votes
I had the same exact problem. I had reloaded drivers for the wireless, quick launch buttons, flashed the bios and even replaced the wireless card. After all this I uninstalled the software for the hp wireless assistant and quick launch buttons and under the advanced tab in wireless properties I turned power on to the card. After that everything worked exactly as it should including sound and wireless button.
Hope this helps someone in the future.
Was this helpful?
Yes
No
Popular Solutions for HP Compaq nc6120 PC Notebook
Questions and Unsolved Problems for HP Compaq nc6120 PC Notebook
Do you recommend HP Compaq nc6120 PC Notebook?
Answer
Answer
I want to replace the cmos battery on my toshiba ps267u4k9j0k laptop and I don't know how to get to... (More)
Answer
sd.ms pro.mmc.sm.xd drivers for HP Compaq laptop not work
Answer
sd ms pro mmc sm xd card not working hp nc6120 laptop - cannot see driver - green light flashes when... (More)
Answer
how to enable Ctrl Alt shift key for my HP NC6120
Answer
the display sometimes blends the moitor colors together and cursor locksup and i can sometime press... (More)
Describe your PC Laptops problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in Burnsville, MN
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
