Question about Motorola Mobility HS850 Consumer Headset
Voice dial problem
I don't know how to make my HS850 voice dial, can u help me?
Voice dialing is usually a function of the phone. You need to read your phone manual to figure out how this is done.
Posted on Nov 06, 2007
SOURCE:
Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
Setting Up Your Voice Mail from page 10 in your manual:
Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number
to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail
to dial voice mail. After connecting, you will hear your voice greeting.
2. Interrupt your greeting by pressing .
3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SCH-u340 Cellular Phone
Voice activated dialing
Try going to Menu > Contacts > Voice Command
Apr 07, 2009 | LG RUMOR Cellular Phone
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Microphone isn't working on my hs850
You can mute outgoing voice during a call by tapping on both volume buttons and tap them again to un-mute.possible you are experiencing this . i did
Dec 06, 2008 | Motorola Mobility HS850 Consumer Headset
How to activate the name caller id on supertooth?
Hi Kazgear,
Voice Dial:
Important: Be sure your phone supports the voice dialing function and that it is activated. Record at least one voice tag. (Please refer to the instructions in your phone’s user manual.) Note: Voice dialing entries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 29, 2008 | Blueant Supertooth Light Bluetooth Speaker...
LG 830 Vantage Cell phone voice dialling
With the slider up. Hold down the send key. Follow the instructions. The voice asks who you want to call. If you close the slider you can use the speaker phone.
Nov 06, 2008 | LG Cell Phones
VOICE DIALING
Dear chuckbonus
Please find below the complete manual for your phone. The phone is indeed voice tag capable. You will find the information requested at page 43 of the user's manual.
http://www.cellphones.ca/upload/manuals/motorola-i880-manual.pdf
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 12, 2008 | Motorola Mobility i880 Cellular Phone
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
Mar 10, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
PANASONIC KX-A144EXS
druk middelste knop ,nr verschijnt !
druk ronde knop rechts,
druk ronde knop naar beneden tot WISSEN verchijnt en druk dan ronde knop rechts en kl is kees
Sep 06, 2007 | Panasonic KX-T7730 Corded Phone
Motorola Mobility HS850 Consumer Headset Logo
35 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
