Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 Front Load Washer
When I start the washer, water just pours out of the front hole just under the detergent dispenser. I check the clothes inside and not a drop of water. Not sure what else I should do.
  • 1 more comment
  • Dcor Oct 09, 2007
    *Water pours out onto the floor is should add*
  • Dcor Oct 10, 2007
    You were right about the blockage of some kind. It turns out there was a sock that managed to lodge itself right were the water was coming into the washer. Thank you very much for assisting me.
  • jd_didier Feb 10, 2009
    I have a similar problem, except the water runs into fine into the tub. However, it doesn't always wash out all of the detergent. If the holes are plugged in the top of the dispenser, how do I correct this?
  • 290 Answers
Remove the dipenser and feel down inside the hole. You will probably feel a detergent build up in the cavity. If so clean this out and rinse with hot water. This problem is becoming more common since people are washing more in cold water to save electricty. Some detergents and fabric softeners will not disolve in cold and it "gums" up the works. Post back to let me know what you find.
Posted on Oct 09, 2007
  • Michael  Lindley
    Michael Lindley Oct 10, 2007
    Maybe I am not clear on your problem. I understand that water is overflowing out of the hole the dispenser slides into and no water running into machine. If this is correct, there has to be a blockage of some kind under the dispenser.
    We have seen cases where the holes in the top of the dispener have become clogged with calcium and lime build-up. This can cause a small amount of water to leak around the dispenser, but the tub still fills properly.
    Remove the dispenser tray and start a cycle. Watch the water come into the machine. It should flow straight down through all the holes just above where the detergent section would be like a shower.
SOURCE:
Managemylife com sears
Either the cylenoid to let the water in is bad.
Or the hose from the dispenser to the drum is clogged.
Most common with powder detergents.
Some really hot water poured into the dispenser may
solve the problem.
Aug 21, 2014 | Kenmore Elite 45986 Front Load Washer
Frigidaire front load washer (GLTF1040ASO) is leaking water by the detergent dispenser area. Any suggestions on what this could be?
This is usually caused by solidified detergent blocking the water ways in the detergent dispenser.
Check the inside of the dispenser to make sure the outlet holes are not blocked.
Most dispensers can be removed for cleaning check your appliance instructions for details.
Dec 13, 2010 | Frigidaire GLTF1040A Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
The Liquid Fabric Softner dosn't dispense completely. Approximately 1/4 of it is left in the chamber.
the problem is that the hole that drains the chamber is partially blocked with dry fabric softener. pour a cup of viinegar in to the dispenser and do the wash using the hot water cycle and no clothes. this will clean it for u
use white vinegar if u have it or apple cider vinegar
Aug 17, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 11047511701 Front Load clothes washer: Liquid detergent runs out of dispenser and down front of machine immediately as liquid is poured in instead of holding liquid. Dispenser was not overfilled.
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 14, 2009 | Kenmore HE2 Plus Front Load Washer
Water pouring out of detergent dispenser drawer
There is a rubber hose that connects dispenser housing to outer tub of washer. Disconnect hose at outer tub and fish out article of clothing that has wedged itself in there cuasing water to back up and pour out of dispenser. In the future use a linen bag for small articles of clothing such as underwear and socks.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
152 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
