Question about Sony 4GB Memory Stick PRO Duo Memory Card
This memory stick may not record or play - Sony 4GB Memory Stick PRO Duo Memory Card
4 Suggested Answers
charcois
  • 763 Answers
SOURCE: memory stick recording
that means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Posted on Sep 19, 2008
rahulwozniak
  • 87 Answers
SOURCE: Hi i have just brought a sony dcr-sx30 handycam
It seems that your handycam does not support the memeory card u put in.
Posted on Dec 20, 2009
illinois68
  • 131 Answers
SOURCE: The memory stick may not record or play
Can you see the files on it? If so, can you move them to your computer and then open them. If you cannot, you may have to try reformatting (and thus losing the data on the memory stick) to attempt getting it back to a recordable/playable state.
Posted on Aug 27, 2010
I DID NOT USE MY TVR460 VIDEO CAMERA FOR 3 YEARS. NOW IT IS NOT RECORDING OR PLAYING ANY TAPE. IT CAN RECORD AND PLAY ONLY ON SONY MEMORY STICK.
Recording / Playback head is metal with a thin gap which quickly becomes corroded from simple condensation - unless stored with water absorbent material in airtight container. Sorry, (you needed a newer model anyway) ;-'
Sep 19, 2016 | Sony Cameras
Purchased a Technika Model 19-220. 8 months ago never used the DVD recorder because we never had freeserve. Now we are connected to Freeserve the DVD will play DVD's but no accept blanks for recording...
Thanks for posting to Fixya and it is my pleasure to guide you.
"Will not accept blanks for recording it says No Disc."
from Technika manual: Start Quote
VCR/DVD Recorder; I have connected the TV to my VCR or DVD Recorder via SCART but it is not recording. In addition to connecting via SCART, you should connect the aerial cable from the wall socket to your VCR/DVD Recorder and another aerial cable from the VCR/DVD Recorder to the TV." Also; "Check the DVD is a region 2 disc - to change the region of the DVD player, refer to section 'Changing Regions'.
Note: USB record function is only avilable in Digital/Freeview TV/Radio mode. Due to copyright laws and illegal copying/recording it is not possible to record to/from any other input/output source.
DVD MENU: To access this menu, press [MENU] button on the remote control. TV System - Choose from the following options. NTSC; Normally used for discs from North America, Japan etc.
Auto; For both NTSC and PAL. This TV/DVD player is pre-set to play Region 2 DVDs.
Tip: This television contains one TV tuner, therefore it can only record the channel you are watching or record one channel while the television is in standby mode.
Tip: This TV/DVD player is pre-set to play Region 2 DVDs.
End Quote
You can not record to a DVD, according to their manual. That is why you get the no disc error. It does not have the play sector at the beginning of the DVD. You can record to USB Flash Drive however.
Quote:
USB RECORD - DIGITAL/FREEVIEW MODE
Built into this television is a USB record facility. This function is available in Digital/Freeview mode when used in conjunction with a compatible USB memory stick or USB Hard drive. The benefi ts of this are as follows:
• Pause live TV/Radio and then playback, fast forward and rewind (up to live TV)
• One button record, if you decide you want to record the current programme
• Easy programmable recording from the 7 day TV Guide
• Record TV/Radio and watch/listen back on your computer/laptop
Due to the nature of the product, it is necessary to use a high speed USB memory stick (as the TV reads from and writes to the memory stick at the same time, some memory sticks may not be suitable). You can purchase high speed memory sticks from some computer stores, alternatively, we have a selection of tested and compatible memory sticks available to purchase directly from the helpline/web site. These are available in 4GB, 8GB and 16GB. (Please check the web site/helpline for latest specifications and prices). End Quote
Good luck and please post back that you this has solved your problem and click thumbs up of your success or that I can be more helpful.
Jun 06, 2011 | Televison & Video
The vids on my Sony DSC-T90 won't play and I can't record. The camera says' "file error"
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Not able to record or play :
This error may occur in any of the following circumstances:
-The Memory Stick® media is not inserted properly.
-The Memory Stick media is not supported for use with the camera.
-The Memory Stick media may be faulty.
Mar 13, 2011 | Cameras
What tyue of memory stick do you need for a eclipse head unit and does it need to be formatted to play mp3
Memory Stick Playback Features
Compatibility: The AVN5495 can only play music data recorded in ATRAC 3 on MagicGate Memory Sticks (white). MagicGate Memory Sticks and standard Memory Sticks can also be used for database updates and ESN. Memory Stick Duo must always be used with the Memory Stick Duo adapter. Memory Sticks with a capacity of up to 128MB are supported. Memory Stick PRO is not supported.
Mar 11, 2011 | Eclipse AVN5495 Car DVD Player
Aug 27, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I need to know how to use the memory stick feature on a Sony digital recorder.
Here is the URL for the manual for your recorder =>
http://esupport.sony.com/US/perl/model-documents.pl?mdl=ICDMX20&LOC=3
Essentially you just plug in the Memory Stick, wait for the display to stop showing "ACCESS". Make sure you do not insert the stick when you are either recording or playing a message. There is a chart that shows you how many messages you can record using the different speeds.
Jul 14, 2009 | Sony ICD-MX20 Digital Voice Recorder
DV Cassettes vs Memory Stick
Well, I went to The Sony site and what I found out was that currently this camera is only ceritfied for a 512mb stick. It does say what the qualiy is the memory stick is E-mail mode with a resultion of 160x112 pixels. The TAPE mode is DV quality or 740X480 pixels. Try recording both ways and see what looks better when you play it back on you TV or PC then decide.
Sep 14, 2005 | Sony DCR-PC350E Mini DV Digital Camcorder
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Sony 4GB Memory Stick PRO Duo Memory Card Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
