Question about Frigidaire FWS933F Top Load Washer
My frigidaire washer does not drain and spin - Frigidaire FWS933F Top Load Washer
SOURCE: Washer Stopped Spinning
My Frigidaire front loading washer is less than 2 years old and YES there is a belt, I am going to replace my 3rd belt this week.....the wheel on the back of the drum has moved enough, even after numberous times of tightening, that it has worn a HUGE hole in the back of the drum from the belts. I will NEVER buy another product from them again, due to not standing behind their product and sending a repair man to my home to fix it, then telling me that I will have to replace the drum....(ltf2940es0).
signed
DISCUSTED WITH FRIGIDAIRE!!!!
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: frigidaire frontloading washer won't spin at all
Have a GLTF2940. Error code E20 and E30 came up. Will not drain and spin.
What to do?
Posted on Jul 28, 2008
  • 196 Answers
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Posted on Nov 12, 2008
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
fernie_elazt
SOURCE: My Frigidaire gallery front load washer won't spin or drain
its ether the transmission or the motor gone bad
Posted on Jun 29, 2012
My front load washer will not spin on the final spin cycle. Washer spins in wash and rinse cycle spin. Cloths are still soaking wet.
I appreciate your post, Rachel Kovach!
From my understanding your Frigidaire frontload washer is not spinning the final spinning and the clothes are still wet. If you washer is overloaded it will not spin properly to release the water out of the clothes. Also, a small load will cause your washer to not spin properly. You should additionally check the drain hose to make sure it not kinked or twisted that could cause your improper draining. If all that checks properly it could be an issue with your drain pump, motor, and control panel. I would suggest consulting with a technician for proper diagnosis and repair. This will help avoid unnecessary part purchases. -Matt
Nov 19, 2014 | Frigidaire Washing Machines
Frigidaire washer will not wash or spin
Hello friend, thank you for your post!
I understand that your Frigidaire washer will not wash or spin. Typically if your washer is not spinning it could be a potential issue with your drain hose. I would check to assure that there are no kinks in your drain line or that the drain hose is not too long. Those could be some possibilities.
If the drain line is clear you could be experiencing an issue with your timer or drain pump. I would recommend seeking assistance from a professional to come out and properly diagnosis your washer. I hope this helps. -Matt
Oct 08, 2014 | Frigidaire Washing Machines
My frigidaire front load washer Model #GLTF2940E will not spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
My frigidaire washer model # fws545rfs0 wont drain or spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 21, 2011 | Frigidaire Washing Machines
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire frontloading washer won't spin at all
What to do?
Jul 27, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire FWS933F Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
