Question about Nokia 3120 Cellular Phone
Screen with lines
I see lines appearing on my screen and it remains.I have three lines on my screen now.Two horizontal and one vertical.It doesnt dissapear.
    Sergeant:
  • 452 Answers
U need to repaire ur display, so contact service centre, if it is in warranty period then replace free display.
Posted on Oct 19, 2007
SOURCE:
There is a line down the center of the screen
whether the line-shaped vertical or horizontal? if it appears a horizontal line on your side, it signifies the vertical rays do not exit the screen or your TV vertical part is not working. damage can be caused by IC Vertical, or in the vertical deflection coil yoke.dan if a line that appears is from top to bottom that indicates the horizontal section is not working, usually there is a problem of the deflection yoke is not connected or defective.
Jul 11, 2010 | Televison & Video
Zenith b25a24z has a line in center of screen and i replace the verticle output ic and the problem remains can somebody help me?
was the line vertical or horizontal? if vertical check on the horizantal sync side if horizontal check vertical side also check for dry solder joint on the circuite.
Apr 07, 2010 | Zenith C27A24T 27" TV
Thin white horizontal lines have appeared on the upper quater of the screen. Under these lines a greena red line has appeared. Bottom three quarters of screen is good.
u have to change a capacitor(470mfd or 100 mfd) in vertical section of u'r tv circuit board..if u r a tech person try this...
Jan 26, 2010 | RCA F27442 27" TV
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
Vertical aqua colored line on the screen of my laptop
the cells inside of the lcd itself are starting to go bad which is why your seeing lines on the screen. To fix the problem you'll need to replace the lcd.
In the meantime you can hook up an external monitor and use that so you don't have to deal with lines on a bad lcd screen.
Jun 26, 2009 | Compaq Presario M2000 Notebook
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Sony tv model no. KV - 19 APR 2
This is for a different model, but I had thin horizontal lines in red and had to adjust the tube for red. You may have a similar adjustment on your set.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Aug 01, 2008 | Sony KP-48V80 48" Rear Projection...
Horizontal lines
sometimes I encounter vertical lines below..... when i tap the sides it clears for a time being  but after a few moment again appears
Dec 06, 2007 | AOC 19LVWK LCD Monitor
Monitor
capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Nov 22, 2007 | IBM E74 17" CRT Monitor
Nokia 3120 Cellular Phone Logo
166 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
