Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Rusting basin The inside basin of my washing machine is rusting, leaving rust stains on my clothes. Can the basin be replaced at a minimal fee or would it be cheaper to purchase a new washing machine?
  • kebert2u Oct 09, 2007
    Thank you so much for your help! I truly appreciate it. My washer is no longer under warranty and is only 4 years old. It is in excellent condition. I just didn't have any idea how much it would cost to repair it versus purchasing another one.
  • Anonymous Mar 16, 2014
    Fell into wash basin. How reinstall
  • 290 Answers
If you still have your book, look in the warranty section. The baskets on most models are covered 5 or 10 years against rust. That covers the part but not labor.($130-$160) If the rest of the machine is in good condition, it would probably be worth it. If you don't have your book, look up your specific model on the Whirlpool website and you should be able to find the warranty info. If it is no longer covered, the repair cost would probably not be worth it.
Posted on Oct 09, 2007
SOURCE:
How can i remove rust from inside of a top-loading washing machine?
If you have not all ready done so try something like iron or lime away through an empty load. if that does not work, most likely you are about to rust through the tub.. good luck
Jun 02, 2014 | Washing Machines
Have had numerous items ruined due to brown stain
My Maytag Front Loader also has periodically caused rust stains on clothes. After investigating it I determined the cause.
The top of the machine is rusting around the opening under the lid where you add the detergent, fabric softener, and bleach. Water apparently splashes up on the bottom of the lid and it rusts. The flakes of rust then flake off and fall into the plastic reservoir and are washed into the machine. The only fix is to replace the top of the machine, or take it off, physically clean off the rust and apply a coating of rust resistant paint to the inside. A quick fix is to remove the plastic cover (4 phillips screws) and clean as much rust off around the edges as you can. Be sure and keep the rust from falling down the hole where the water flows into the machine.
Dec 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Yellow stains after machine washing
Sounds like rust stains, coming off the inside of the drum, you will need to find the source of the rust. Maybe a loose screw or something metal stuck inside the drum. Carefully run your hand around the inside of the drum and check for rough jagged edges to identify anything that should not be in there.
Aug 21, 2009 | Washing Machines
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
My WASHER IS RUSTING INSIDE THE TUB WHAT SHOULD I DO AFTER I WASHED MY CLOTHES THERE IS ALWAYS A BROWN OR RUST STAIN ON MY GARMENTS.
Change the tub or ?
If it is an enamel coated tub then you can buy a paint to cover it over
It is normally sold to repair chips out of wash hand basins
If you know someone who does car repairs they may be able to cover it with a GRP resin like they do on the bottom of a boat
Jul 06, 2009 | KitchenAid KHWV01RSS
Do I need to descale or rust treat my Washing Machine?
  • this is a common problem with aging kenmore washers (leaving coins in your pockets speeds it up).
  •  the basket is metal with a porcelain coating. the porcelain coating wears around the edge of the holes in the basket first, leaving bare metal.
  •  when the washer spins the centrifugal force pushes the clothes against the basket and a little into the holes. this leaves little rust rings on your clothes.
  • lumpy816 is correct in saying that your basket should be replaced. it does require a special tool, and the basket is expensive.
  •  in the mean time try to take the clothes out immediately after the washer stops spinning. and if you get desperate you can clean thee inside of the tub with a rust remover like LCR or a strong toilet bowl cleaner that removes rust.
Jun 30, 2008 | Kenmore 24032\24036 Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
202 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
