Question about Sunbeam 2366 MixMaster Series Hand/Stand Mixer
Model #2366 mixer blade release problem
Hi, The white plastic pushbutton release on my Sunbeam #2366 hand/stand mixer has broken internally (and is now residing inside the mixer body). This mixer is about 6 years old. Does this sound like an expensive repair? A new #2366 retails for about $145.00. Thank you for your time and consideration. Lori
  • catwoman2 Dec 24, 2007
    It sounds like my mixer, which also is about 5-6 years old, has a similar problem. I have the chrome color version and the stand is actually some kind of hard plastic made to look like metal chrome. The black push button release that holds the mixer to the stand simply fell into the inside of the stand. This happened last Christmas when I got ready to do my baking. At that time, I unscrewed the four screws at the bottom and retrieved the push button and tried to figure out how it was attached. It was a mystery to me but I got it reinserted so that it would at least hold the mixer in place.
    Well, I just got the mixer and stand out of the cabinet to do my holiday baking this year and found that the push button had fallen inside the stand again. This time, when I tried to fix it, the little plastic piece where the push button goes inside the stand broke. So, there is no way to make the push button stay in now. This stand is really cheaply made and ill designed. I can't believe they would make a lightweight, plastic base for such a heavy weight mixer. I have a perfectly good working mixer on top and a broken stand which pretty much makes the whole setup useless. I'm not buying another one of these that's for sure.
  • coacha67 Feb 14, 2008
    My problem is that same as previously described, my mixer is 6 yrs old. I unscrewed the base, retrieved the cracked plastic piece. Superglues the crack, when dry put it back in place and it lasted for one round of cake mixing. I'm back to a broekn piece. Am currently searching for a replacement mixer release trigger.
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Posted on Nov 04, 2008
SOURCE:
Where can I buy replaement beaters for a Sunbeam Mixer Model MM1000
Look for a nearby dealer or repair shop. If that doesn't work, try http://www.goodmans.net/d/159/sunbeam-mixers-parts.htm
Dec 16, 2014 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 2366 mixer - how do you replace the mixer release trigger
Look at this site.
http://sunbeammixmasterlove.tumblr.com/tagged/manuals#.U50ef5Qs6So
Jan 01, 2014 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 275 watt 2366 mixer
it is probably the swich /pot combination on the electronic board. The shaft on the unit I have had twisted off and would no longer turn the switch on or off.
Feb 02, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 2366 MixMaster Series Hand/Stand Mixer Logo
394 people viewed this question
Top Sunbeam Food Mixers Experts
Vincent G
Vincent G
Bruce Showalter
Jerry Greenberg
Jerry Greenberg
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
