The unit vibrates and has a pulsing sound. I have it on a rubber mat but you can hear it even upstairs. Seems to work fine just loud. The unit is a Danby Simplicity 50 pint SDR505R 43-5410-2
These things tend to make a bit of noise, some more than others. You will not be able to do much about the internal produced noise but you can do a lot with the resulting vibration noise.
While the unit is running, take a few minutes and actually touch the unit ALL OVER, you are listing for any vibration noise to cease or be less so where you are touching. This includes the collection pan and the filter. Slightly Tilt the unit in all directions. Make sure that the door to the collection pan is closed properly. Take a few strips of the peel-off adhesive sided thin window/door insulation and apply to the bottom of the collector pan, if it sits ON the bottom of the unit. Place an inch or two thick blocks of foam rubber under each corner of the unit. Make sure the unit is level. Some where along here you will stifle some of, or maybe even most of the noise.
Good luck. :)
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if...
(More)
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if purchased brand new and if this is a good product. The asking price is $275.00 with 50 ft of hose to drain outside. Thank You for your help, Kristina
small basement efficiency that is not occupied during cold months, and accumulates mold and paint...
(More)
small basement efficiency that is not occupied during cold months, and accumulates mold and paint damage while unoccupied
My Soleus dehumidifier has stopped working after one year. The fan is running, the compressor seems...
(More)
My Soleus dehumidifier has stopped working after one year. The fan is running, the compressor seems to be hot and it is not condensing water. I have the controls on high and continuous run.
None of the buttons work:power, humidity control. Basement seems to be damp still. Do we need to...
(More)
None of the buttons work:power, humidity control. Basement seems to be damp still. Do we need to replace the whole unit?
