Question about GE Refrigerators
Reset control panel ge refrigerator - GE Refrigerators
SOURCE: GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Posted on Sep 15, 2008
  • 146 Answers
SOURCE: GE monogram Side-by-side (42inch) built-in is showing "low Temp"
I gather your compression cycles on because you have SOME cooling. Your refrigerator should NOT be warmer than 40 F - the range is usually 34~40F, ideal is 36F - anything warmer than 40F is no good.
For the condenser, older models have the condensers at the BACK of the fridge - make sure you have proper clearance at the back of the fridge - newer refrigerators have the coils at the BOTTOM of the fridge into an open space - you cannot completly clean those with a vacuum - you will need to purchase a condenser cleaning brush long enough and allowing you ewasily reach them from under your fridge - you can usually locate those in your hardware store or go to your local appliance store parts center and see if they have it.
As to being low on freon - you never get low on freon, it's a sealed system and the coolant does not run out - you will only need a recharge if you have a sealed system leak - rare but it can happen - you will have to get service to locate the leak first, they have the equipment for that, fix it and then recharge - this is NOT something you can do yourself.
You could try removing the back panel of your freezer and locate the cooling coils under the evap fan - are these over frosted (evenly), then you have a defrost timer problem, you will need to service the defrost timer control and its components. If only part of the coils are frosted, example to the left and the rest is frost free this is a symptom of a leak in the system........either way you will have to get your unit serviced considering it's been 15 years and over - the average life cycle of a compressor is 10 years - some can last longer, and it seems newer ones last much less too - after all these years time to get it serviced - and you better hope it's not the compressor it will cost you ! I hope it's nothing major -and as simple as a defrost timer control board - you can rule that out yourself by shutting down and defrosting manually using a hairdryer (assuming your coils are completly frosted up) if you run fridge and it cools, you got your problem......defrost control! Otherwise partially frosted my bets would go on leak...... You might want to check other sources of cold air leaks through poor gaskets on your doors using the dollar bill method and pulling looking for some resistence.
if all of the above fails and your compressor is bad, it's time for a new energy efficient refrigerator - a compressor that old will cost you at least $400 + the service call + the hourly rate.......
Posted on Aug 24, 2009
  • 4369 Answers
SOURCE: I cleaned the control panel and distrubed the
did you accidently put it in "showroom mode"? unplug it and plug it back in.
Try that first. Report back.
Posted on Jan 13, 2010
  • 161 Answers
SOURCE: GE PSS26MGTABB Side by Side Refrigerator not working at all
the mother boards are not always obvious...but thats yer guy
Posted on Mar 03, 2010
MNTECH
  • 1543 Answers
SOURCE: "Is there a "defrost" feature
Yes, there is an automatic defrost feature on those models. It is controled by the main electronic control board (mother board) and energizes a defrost heater located under the evaporator (the cooling coils behind the back wall in the freezer). You are setting the freezer temp to zero, but the display return to the actual temperture. The icemaker will not make ice unless it gets below 8 degrees (F). The ice build up indicates a problem. It may be the defrost heater, defrost drain blockage (drain at center of evaporator, directly below it) or a problem with the evaporator fan (the fan inside the freezer). The ice build up could also be caused by a door which did not or is not closing fully, allowing warm moist air to enter the refrig / freezer, causing an unusual amount of frost to deal with. The frost is blocking the cooling coils, preventing transfer of heat to the coils, thus poor cooling. Left unchecked, the freezer packages will begin to thaw and refrig temp will rise soon also.
To get to the evaporator coils, the freezer door, ice maker, dividers, and one side of the drawer slides on the side of the freezer compartment must be removed, allowing the back wall inside the freezer to be removed. Your most likely problem is the defrost heater. Melting all the ice off the coils with a hair dryer will get your unit working fine for at least a week, allowing time to get and install repair parts. There is no fire danger. The orange glow you speak of would be the orange glow at the very back bottom of a freezer when it is in defrost and the heater is on, but on your model, I don't think there is enough air venting there to actually see that with the back wall in place (and if the heater is burnt out, you would never see it anyway). Also, check the icemaker itself to make sure there is no object in it which would obstruct the ejector arm from completing it's revolution to eject cubes. A stuck ejector would add heat to the freezer, but I don't think this is your problem, as that would not account for the ice you see near the icemaker. If you don't want to go through all the work of doing the diagnostic and repair yourself, just unplugging the refrig and leaving the freezer door open for 24 hours will defrost it and get it to work for another week, but a repair person would like to see the unit as it is now, rather than after you have manually defrosted it, if possible.
Posted on Mar 24, 2010
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
Jul 01, 2016 | GE Monogram Side by Side Refrigerator
Panel beeping and nonresponsive
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 30, 2016 | GE Profile Stainless Bottom-Freezer...
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Control panel for GE PFE29PSDSS
All models that have electronics are easily wiped out during storms due to the sensitive electronic controls on all of the control boards. Your model has the=> WR55X25146 Main Control Board the WR55X11138 Inverter Board and the dispenser control board. You will need to exchange parts until you get the right board. Most likely the motherboard,
Appliance 911 Sea Breeze
Aug 03, 2015 | GE Refrigerators
We have a ge profile Artica, refrigerator side too cold. Keeps resetting temp to 27 degrees. Freezing everything.
Unplug for 20 seconds & plug back in... if keeps happening, replace the front panel controller.
Feb 21, 2015 | GE Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
Jul 24, 2010 | GE PSS26SHRSS Side by Side Refrigerator
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
