Question about Canon PowerShot A540 Digital Camera
Memory Card Problem
I recently put my 1GB memory card into a digital picture frame. It had always worked fine, but when I took it out and put it back in my camera none of the pictures would display, the screen says "no image" I cant download them onto the computer and I cant take new ones because it says the card is full (which it is, but I cant see or access any of the images.) This really sucks because its about a thousand pictures I took in Europe this spring :(. Id appreciate any suggestions. I'm fairly certain its not the camera, my room mates memory card works normally in it.
  • 1,894 Answers
Re: Memory Card Problem
Hey see page 105 of ur camera manual. if u dont have it see from canons site.
its says as follows:
sotry as i say. get one card reader and take back up of al the photos in your computer in which u have cameras EOS utiliys installed. now u have took back up of photos.
put tat memory card in your camera and do a low level format. this can be found from the options in menu in camera.if u dont get that ask me.
after formating it. connect the camera to computer and transfer the photos to the camera. your work is over i think. if not ask me. thank you
Posted on Dec 22, 2007
0 characters
3 Points
I can see all my pictures that I took on my camera but when I put my memory stick in the computer and at Walmart photo lab they are on my memory stick..why?
Trying taking the memory card to a computer and looking through it for the photos. Take them off and put on pc. Then format memory card. Place memory card back in camera and take a picture. Then put memory card back in pc and take original photos and drop into folder that has new picture you took. It should work by noe if not then get a new memory card. Then try again.
Jul 05, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Digital Cameras
My z950 is not reading my memory card. I got it a couple of weeks ago and it was working fine. I took my memory card out to print pictures and when I put it back in, the screen keeps saying internal...
make shore the memory card is out of the camera and reformatte the interal memory and reset the camera ,turn it off and put the memory card back in it should work now.
Aug 29, 2010 | Kodak EasyShare Z950 Digital Camera
Panasonic Lumix DMC-TZ5 does not recognise my memory card
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the instructions.. 3. After downloading any pictures from the card, insert it into the camera and do the "format" thing again. everything should work now. Remember, never use the computer to format or erase your card...always use the camera. Also, when removing the card from the computer, always use "safely remove hardware" icon at the bottom right of your computer screen.
Feb 16, 2010 | Digital Cameras
I can't get to my pictures!
did you buy a memory card along with your camera? I got the camera and they threw in a memory card with it for free. I now know why. My pictures will not always save onto this memory card. i took the memory card out of my old camera and put it in this one, and, the pictures saved. strangely, when i put my new card back in my new camera and took a picture; it saved to it again!
so i believe this could work for you. it sucks. you lose the pictures. but atleast the camera does not have to just be thrown away.
Jan 22, 2009 | Fuji Finepix Z20fd Digital Camera
Memory card fault or camera fault?
When the camera writes the image files to the memory card, it also creates index/information files. Without those files the camera will not display the images.
Check the software you used to upload the images with. There's probably a checkbox or option that tells it to delete the images from the card after uploading them.
Nov 29, 2008 | Gateway DC-M40 Digital Camera
Fuji FinePix E550
format by going to option while in shot pic mode , first press ok then option, set-up go down to format and after should be working.
Sep 05, 2008 | Fuji FinePix E550 Digital Camera
2 gb memory card displays "full" with only 8 pictures
Samsung only guarantees that a 1GB external memory card will work. If you look at the user manual on page 77. I just used a 1GB memory card instead and it worked fine.
I am not saying that no memory cards greater than 1GB will work, but if it doesn't work or stops working then it is because the software for the phone is not set up to handle it. I had the same issue and had to switch to a 1GB card.
Jul 16, 2008 | Samsung NV3 Digital Camera
Memory card problem
wheather you check in computer repair shop is their any virus present in memory card? format your memory card! check virus is present in your computer or not! ?Try it!
Jul 11, 2008 | Nikon Coolpix S3 Digital Camera
Memory Card
Format the card in the Camera- read your manual
Jul 31, 2007 | Fuji FinePix A500 Digital Camera
Canon PowerShot A540 Digital Camera Logo
129 people viewed this question
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
