Question about Rockford Fosgate Power 1001BD Car Audio Amplifier
Rockford 1001bd blowing fuses...
Hey my 1001bd stopped working the other day. I heard a pop sound and then no more bass. The fuse on the power cable was blown so I replaced it and as soon as I turned the ignition on the fuse burnt immediately. I tried it again with the same result. Any help would be super appreciated. Thanks
  • beldo Oct 11, 2007
    The fuse is not visible from the outside of the amp. Is it possible that it has a fuse inside that I would have to open it up to get at? They used allen screws on the amp that don't fit any of my metric or imperial allen keys. I checked the ground and the power, they are both clean and only installed about a month ago professionally. I think my amp may be damaged and there is a chance that the day it stopped working it may have gotten a drip of water in it as there was a small spill in the back of my car..... not sure though.
  • stopdat Mar 17, 2009
    I bought the Rockford Fosgate 1001 BD amplifier a few years ago. It had been playing perfectly until early last year. I switched off the car stereo one night only to hear a pop noise come through the sub woofer. I later realized that the supply fuse was blown, and replaced it. On attempting to play music again, the fuse supplying this amp also had blown, and keeps blowing fuses. I do believe there's an internal problem with the amp hence... a short circuit. Does anyone know where i can get this amp repaired here in the Uk.
    Problem Solver:
  • 5 Answers
It sounds like you've got a short to ground in either your power line or internally in your amp. Either that or the fuse on your amp (usually right on the side) might be blown. Check your power line and make sure that your amp isn't screwed directly to any metal parts of your car, as some amps will short like this. If there's nothing wrong with the power line, send it in for warranty or bring it to your local audio store to have them check it. If you feel comfortable with trying to fix it yourself, then take it apart but be advised that internal screws usually have a glued spot so they can tell if you've disassembled it.
Posted on Oct 08, 2007
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
Jan 09, 2014 | Peavey Electronics Peavey Tour Tnt 115...
95 gmc yukon tailights not working
You can find wiring diagrams at http://www.bbbind.com/free_tsb.html free ! Enter your vehicle info. year , make , model an engine size . Under system click on lighting , subsystem click parking lights . Do the stop lamps work ? Turn signals etc.... Which fuse blows ? Also check fuse box diagram under power distribution ,fuse box .to see what all that fuse powers
Mar 25, 2017 | 1995 GMC Yukon
BassCube 12 Startup Problem
same here. happened after moving residences
Jun 30, 2008 | Cambridge Soundworks BassCube 12 Speaker
Old rockford fosgate power 1001bd
The 1001BD will produce it's rated power (1000 watts RMS into 2 ohms).
Nov 25, 2007 | Rockford Fosgate Power 1001BD Car Audio...
Blowing fuses
check your car battery and check your ground and check your power wire for any splits or cracks
Nov 22, 2006 | Rockford Fosgate Punch P3002 Car Audio...
Rockford power 1001bd amp
There are two LEDS. One on top and one on the end. Did both light up? If not, which one lit up?
Sep 13, 2006 | Rockford Fosgate Power 1001BD Car Audio...
Rockford Fosgate Power 1001BD Car Audio Amplifier Logo
142 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
