Question about Casio 76 Key Smartmedia Keyboard
I am getting tones out of every other key on my casio CDP 100. Meaning if lowest base c is working the next c is not. The third is and the fourth is not. All the notes are the same. either the first
If base c is working the next one is not. As you move up the keyboard the third c is while the fourth is not. This applies to all the keys. If there is tone on the first there is none on the next but yes on the third etc for all the keys....
  • 21 Answers
Check the track connecting the keys .their should be cracks or dry solder.I think that should solve your problem.
Posted on Nov 22, 2013
  • 979 Answers
SOURCE: Casio WK 1600 : Sustained keys
Remove all power sources for at least 2 minutes. That means removing the batteries and power cord completely from the K board. Then try again. If that doesn't do it, it'll be time for a service visit...accordianman
Posted on Nov 19, 2007
  • 2976 Answers
SOURCE: Notes not holding
The key contacts need cleaned.
Posted on Aug 10, 2009
  • 5603 Answers
SOURCE: need power cord for Casio CA-100 Tone Bank
You need a 9 volt DC adapter with at least 850ms (0.85 amp) capabilty with the center the minus polarity. A good place to find thes is thrift shops, but DO be careful that the center is the MINUS polarity.
Posted on Jan 22, 2011
  • 5603 Answers
SOURCE: hi, i have a problem with
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Posted on Jun 14, 2011
  • 5603 Answers
SOURCE: the keyboard works fine but
Read your manual regarding "fingered chords" and similar subjects. It sounds like you are in a single fingered chord mode...
Posted on Jul 21, 2011
CDP100 CASIO PIANO VOLUME CONTROL SCRATCHY. UNABLE TO ACCESS THE POTENTIOMETER. PL HELP
Try this first with the piano off, run the control from stop to stop rapidly several times. The object is to clean off any dust deposits and shine the contacts inside the pot. If the pot is not damaged beyond repair, then this should fix it.
Dec 05, 2016 | Casio Cdp-100 88 Note Digital Piano
I have a Casio cdp 100 keyboard and two of the keys are stuck in the down position. Almost like the spring has gone in these 2 keys. Can this be fixed and if so, how?
is it under warranty ?
if not
you may have to contact your point of sale to find their local repairer
if you cant un stick them yourself that keyboard will have to be taken apart
are the two keys ... white keys or black ...nearby or way apart
do the two keys drop loose..and lift up
or stay down
example will vacuum cleaner suction help lift the stuck keys or not
sales blurp says this
A spring-less hammer system
Scaled Hammer Action Keyboard
https://www.jbhifi.com.au/musical-instruments/casio/casio-cdp-120-digital-piano/91120
Jul 31, 2016 | Casio Music
How do you replace a key on a casio 100 keyboard. which screws do you remove in the back
What kind/type of your Casio 100?
Casio MT-100,LK-100,CA-100,PT-100,CDP-100 ?
May 19, 2015 | Casio LK-100 Keyboard
Casio CDP - 120 turns itself off
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
If it turns itself off while playing, I would try to buy a new AC Adapter to test. DC cable of AC adapters are often broken internally after much "bending".
Jan 06, 2014 | Casio Music
Note not functioning
Possibly dust. May need to make an appointment to see Dr Casio if you haven't got it fixed yet
Sep 24, 2013 | Casio Cdp-100 88 Note Digital Piano
I have a CDP-100 and one key isn't working. When pressed there is no sound
you must open the case and change the rubber contact under the key isn't working
Mar 16, 2013 | Casio Music
Disfunctioning f note. It plays extremely loudly.
If it is under warranty, may as well make use of it. In the long run it will be less headache for you.
It is something that should be repairable, although time consuming. as it is likely a stray bit of solder lodged where it should not be.
Feb 06, 2012 | Casio CS43 Stand for CDP 100
I have a CDP-100 and need disassembly instructions for access to internal keyboard assembly. Unit was dropped while unloading from car. Now some keys are akimbo and won't play as though they are off their...
I just fixed my CDP 100 which had a similar problem - dropped and two keys not working up one end.
1. Lay keyboard upside down on soft surface. Under keyboard is plastic cover held on by 17 screws. Remove all these and lift cover away. The metal key ends are all revealed.
2. Locate the disloged keys. Carefully press them back into position - they will "click" into place. Make sure the corresponding key on the keyboard isn't stuck in an "up" position - you may have to remove the metal key part and replace it again while making sure the key is correctly seated.
3. Replace cover and screws.
Feb 22, 2010 | Casio Music
Casio 76 Key Smartmedia Keyboard Logo
73 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
