1. Camera had fatal lens error (therefore purchased 'new' one)
2. Purchased ("only used twice") CP L4 on Ebay
3. HELP!
Okay, popped MY memory card in... cool, yes? then , NOTHING, but NOISE shows on the display monitor... All images on card are viewable just fine (so I know it's not the LCD screen--right?), but I can't take picture, there's nothing there! Please tell me it's something easy to fix!! I'm leaving for Italy in five days and need this camera!
my problem is cemera is not starting i pressed on buttom then bling red light stoped. there lence shorter is not closed my problem is cemera is not starting i pressed on buttom then bling red light stoped. there lence shorter is not closed
AnonymousNov 06, 2007
the camera when it is switched on it is showing lens errorthe camera when it is switched on it is showing lens error
AnonymousNov 28, 2007
When i turn on my cmera the lens goes out bit then retracts and says lens error.When i turn on my cmera the lens goes out bit then retracts and says lens error.
AnonymousFeb 24, 2008
I have the exact same problem. Had the camera for about 5 weeks. I turn on the camera and it read "Lens Error" and turns off. I cant take it back, unfortunately, but I'm hoping someone knows what to do.I have the exact same problem. Had the camera for about 5 weeks. I turn on the camera and it read "Lens Error" and turns off. I cant take it back, unfortunately, but I'm hoping someone knows what to do.
AnonymousMar 24, 2008
Turm my camera on and it only shows lens errorTurm my camera on and it only shows lens error
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
I work at an authorized Nikon service center and I don't see many S3000 models coming in for repairs. Most camera point and shoot models that have an extending lens are subject to lens errors. Most of those errors are also a result of shock or impact and not manufacturer's defect. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
Hi, When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info. Thanks.
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card) 2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
This may not be able to be fixed. Sounds like internal trouble. Could be a loose link internally. Could be some problem with the ccd sensor. If the colors change as you are trying to take a picture, then suspect the ccd sensor. If it is the ccd, then Nikon may fix it for free. I suggest you go to the Nikon website for your country, and call the (usually toll free) number for service and information. Take care,
NICON COOLPIX L3
a lens error, lens is out and does not want to go back in. Not able to use camera.
