Question about Hoshizaki Refrigerators
Ice machine draining too much water - Hoshizaki Refrigerators
2 Suggested Answers
  • 31 Answers
SOURCE: The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Posted on Mar 13, 2009
Dce33a1bb ice maker makes ice but doesn't stay frozen
Poor draining of water in the ice bin will cause a high rate of ice melting, Remember this is not a freezer but an ice maker. If the machine is making ice OK but it is melting to fast then check to make sure the bin is draining all the melt off and not letting water stand in bin causing ice to melt fast.
Sep 05, 2014 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman ice machine
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Hi i have km-320-mwh hoshizaki ice machine, this machine is discharging water in drain continuesly except when it is dumping ice is this normal ...too much water is being lost please help many thanks...
By looking at the model number it is a water cooled unit. It will dump water down the drain continuosly as that it how it cools the compressor. If it was a MAH it would be air cooled and no continuos dump of water.
Aug 09, 2011 | Hoshizaki Freezer Commercial Ice Machines...
ICEU220HA1 ice machine is half full of water - water fills up through drain hole in the tub when cleaning/purging pump
You have a restriction in the drain line beyond the ice machine and the water is backing up into the unit. You can try some Drain-o or snake the drain.
Apr 21, 2010 | Ice-O-Matic ICEU220HA Undercounter Ice...
Hoshizaki ice machine makes ice but won't drain. Makes ice but won't drain properly, after about 3 or 4 days water starts leaking out of the machine onto the floor. Removed all ice and water and repeated...
My first question is, does the drain have a vent in it? If not, you may need to install one to be able to break the vacuum experienced when the unit flushes after a drop of ice. The vent will be a tee off the drain and a stand pipe that goes up about 5-10" vertical. My next question is has the drain in the plumbing (not the ice machine) been flushed, snaked or tested to see if it can handle the amount of water the ice maching dumps?
Jan 17, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Nov 07, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
May 23, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
Jan 16, 2009 | Hoshizaki KM-1600S Stackable Crescent...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Open Questions:
Refrigerators Logo
37 people viewed this question
Top Hoshizaki Refrigerators Experts
J Rosado
Marat Brikov
Jorge Rendon
Jorge Rendon
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
