Nikon D80 Digital Camera with 18-135mm Lens
Problem for Nikon D80 Digital Camera with 18-135mm Lens
Nikon D80
By kbrock on Oct 08, 2007
I have a nikon D80. The camera will focus, but not take a picture unless i put the lense into manual mode. Any thoughts?
Same Problem
Oct 16, 2008
-   Camera -   nik0nd8o
Mar 03, 2008
-   Again exact same problem as the first user mentioned, is this a common problem with the 135mm lens? I have tried removing the lens as advised but to no joy, my camera still will not take a photo, i can hear the lens focusing but it just wont allow me to take a photo, all this in auto mode. In manual mode the camera works fine...
Any advice would be very welcome...
-   tom_london
Nov 06, 2007
-   We are experiencing exactly the same problem and would appreciate any tips to remedy the situation.-   Lauri16
Best Solution
posted on Feb 11, 2008
Very Helpful)
Bootcoot
Rank: Apprentice
Rating: 100%, 1 votes
i had the same problem occur a couple of times. i found that removing and reinserting the lense cured it!
Was this helpful?
Yes
No
Solution #2
posted on Nov 04, 2008
Very Helpful)
akuss15
Rank: Guide
Rating: 85%, 4 votes
EXPLANATION.
1. The problem with 18-135 lens is because it make from plastic. Main problem from plastic is it can be reshaped after a few usage. When the shape ran out, the contact point will be defective. When the contact point didnt really touched, the processor cant send signal to lens to do autofocus (the lens focus using the lens motor, not the body). When u set to manual focus, the body doesnt need to instruct the lens to focus.
2. You are focusing something that is to near than the focal point.
SOLUTION.
1.Try cleaning the contact point on the lens. Then mount it back until the F showing up (F= aperture). This solution depend on your luck too. if the gap between to contact is so far, then it might happen back. Usually when u need it badly. haha
2. try to get more distance from your subject. Just keep press the shutter until the camera focus.
CONCLUSION
1.But new lens with metal mounting. It will last and durable.
2.Buy macro lens to close up. normal lens wont focus at short focal point!!~
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Mar 10, 2008
Not Rated)
Paul319581
Rank: Wiz
Rating: 83%, 96 votes
I had a issue like this..
the service person in the Nikon told that the lens had problem with alignment !
so i gave it for service !!
Was this helpful?
Yes
No
Solution #4
posted on Mar 09, 2008
Not Rated)
CanadaBruce
Rank: Wiz  Nikon Expert
Rating: 81%, 53 votes
The camera shutter will not work until the green focus light is fully illuminated in the view finder (green dot on the extreme left).  Auto focus sometimes goes into a "search" mode which does not necessarily end up "in tack sharp focus."   Also, depending on the lens you are using, there is a minimum focus distance at which you are limited for focus for the lens.  Check the lens specs.
Good luck.
Was this helpful?
Yes
No
Popular Solutions for Nikon D80 Digital Camera with
Questions and Unsolved Problems for Nikon D80 Digital Camera with
Do you recommend Nikon D80 Digital Camera with 18-135mm Lens?
Answer
Answer
there's some dust spots in my pictures with my Nikon D80. I have sent it for sensor cleaning at... (More)
Answer
The auto focus on my d80 with 18-135mm will not work and creates a very high pitched and/or grinding... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital... Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
