Question about Mitsubishi VS-55609 55" Rear Projection Television
Sony wega kp-51ws520 wont turn on 4 flashing red LED lights in front turn on with remote and blinks red 4 times and shuts off
Turn on with remote and get 4 flashing red LED lights, then it turns off. I hear a click when i press power btoon to turn it on with the remote. I tried reset and no change. what could it be ?
TVtechmaniac
  • 140 Answers
SOURCE: won't power up
This model has had problems with the keyboard buttons on the front panel,causing them not to work and canceling out the remote operation. To verify this,you need to remove the front panel so you can access the connector on the keyboard pc board and unplug the connector.After doing this,see if the remote control is able to turn on the tv (wait for it to power up because with the connector off, the green power light will be disconnected and will not light up when the tv is on) If the tv works, than you will need to change the ten individual switches on the board - part# 432P089010 (or just use the remote only)
Posted on Aug 21, 2007
Slinteriors
  • 8617 Answers
SOURCE: Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Posted on Apr 07, 2008
patopato
  • 3 Answers
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
Posted on May 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
SOURCE: Mitsubishi Medallion does this
may be there will be some loose connections inside you need to find and should solter it ............if warranty is there go for it...................because repairing by own will void warranty
Posted on May 26, 2008
Sony wega tv kp 51ws520 keeps turning off after the standby red light blinks 10x's
problem with str ic need replacement has an internal short need a tech to do it
Jul 08, 2013 | Televison & Video
I have sony wega sony wega tv kp 51ws520 no turn on just standby light blinking and i lost remot plz help me
Is the light blinking 9 times? If so thats a very common problem caused by failed diodes on the G board which will need to be replaced.
Jul 19, 2011 | Sony KP-51WS520 51" Rear Projection...
Sony kp-51ws520 when turned on just has standby light flashing . the rest is all dead, no picture or voice.
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem.
Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Jul 21, 2010 | Sony KP-51WS520 51" Rear Projection...
The standby light just blinks when i try to turn it on and it wont turn on
Count the number of blinks of the standby light. It will bink a count, pause and do it again (Common counts are 2 -9) Give this count to a Sony service center and they can help you know what the issue is. (Probably the lamp)
Apr 17, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
2004 Sony 52" Wega dont turn onnthe stand by light stays flashing. This TV first started by taking long to turn on and now and then would turn off until one day it just didnt turn on and the standby button...
When that model Sony shuts down the LED starts blinking as you say but it is telling you something because it blinks a certain number of times and then pauses and repeats the number of blinks. Count the number and then I might be able to help you narrow down where the trouble is.
Jun 14, 2009 | Sony KP-51WS520 51" Rear Projection...
Wont turn on
Nine blinks means, "Zero Crossing Detector".  The probable cause listed is "D6116 or D6301 is open (G board). (http://www.manual.agoraquest.com/viewtopic.php?topic=22865&forum=34 )
If you don't know what this means I'd reccomend contacting a certified electronics repair shop.
May 24, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Dec 08, 2008 | Sony KP-51WS520 51" Rear Projection...
Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
Television wont power on
Is the led blinking? If so please let me know how many blinks its making before pausing for a second.
Apr 13, 2008 | Sony KP-51WS520 51" Rear Projection...
Open Questions:
dear wish ko lang.magandang umaga o hapun po ms.vicky morales ako po si evelyn alfonso bagsaing lagi po ako na nonood ng programa u gosto ko pong huminge ng tulong sa inyo sana saudi po ako kaya po ako napunta dito para matopad ang mga pangarap ko saking anak at family ko kaya lang po nabigo po ako akala ko po sa pag punta ko diyo sa saudi mabibigyan kona ng magandang buhay ang familya ko n mabigyan ko ng sariling tirahan hinde ko po na alam ang gagawin ko dahil po masaklap ang kalagayan ko dito kaya po ako tomakas sa amo ko kinde ko kaya ang ginagawa sakin hirap na po ako kong papano ako makakauwe kaya lumapit po ako sa programa ninyo na bmatopad lahat ng pangapar ko para hinde na ako malayo sa anak ko na tigil na ang kanyang pag aaral dahil minsan lang po ako nag papadala pag nag karoon po ako ng trabaho dito ang hirap po ng kalagayan ko na maging tnt sa lugar na to wala din po ako magawa kinde gumagat sa patalim para lang maging ligtas ang kalagayan ko sana po matolongan po ninyo ako alam ko pong marami na kayong natotolongan ng programa ninyo eto po ang add ang anak ko si jonathan b estremos..block 10 dita st tenement taguig..sana mabigyan yino ng magandang tirahan kami ng magulang ko ako nalang po ang inaasan ng nanay ko wala n po akong tatay pls po ng makauwe na rin po ako sa piling ng anak ko at nanay ko sa mindanao..rosalinda a bagsaing brgy del carmen press roxas north cotabato.eto po ang add ko at cel number 00966533531704 evelyn alfonso bagsaing riyadh saudi arabia
Feb 23, 2012 | Mitsubishi VS-55609 55" Rear Projection...
See all Mitsubishi VS-55609 55" Rear Projection Television Questions
Mitsubishi VS-55609 55" Rear Projection Television Logo
26 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
