FixYa.com
Tags:
RCA P52937 52 in. Rear Projection Television
RCA Projection TV model #p61926 (by 7 users)
posted by qutecpye on Oct 08, 2007
Pictuure is not focused, tv screen curves the picture with half upside moon at the bottom and half moon at the top. Each indvidual in the picture has shadows (you can see the layout of the picture behind each figure in the tv) and each text on the tv gets curved so is the tv menu and this is happening on all the connections. Please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
6 Other Users Have The Same Problem
Comment by Guest, posted on May 23, 2008
my tv the pictures have doubled and the picture curves in the center
Comment by Big Busy, posted on Apr 08, 2008
i have a curved picture on my rca tv and it is sort of blurred
Comment by Guest, posted on Jan 06, 2008
I have an RCA, model P61926, and my colors suddenly separated--red, green, blue. (Very much the classic hour-glass affect that others have described.) I have read a bit, and learned that the problem is likely my "color convergence." However, following the threads that I have found, pushing on the "STK" module doesn't seem to have any affect! What am I missing?
There is a lot of dust inside the TV. Is this user fixable? I'm not afraid to try. Anyone know what the cost of this fix is? Or where to start?
Comment by DougJ, posted on Dec 05, 2007
Same problem - I'm seeing double! Also, with the hour glass problem. The repair place says it is a convergence problem and to go into the menu. However, there is nothing in the menu that will allow me to fix that.
Comment by ken3071, posted on Dec 04, 2007
Have the same problem with my RCA bigscreen looks like I'm looking at tv through a fishbowl. the tv would be on and suddenly would cut out and then come back on it did this maybe 12 times or so and made a pop sound and came back on and the screen looked like it does now, still works just looks wierd, it hasn't cut out anymore since this happened. any help would be appreciated.
Best Solution
posted on May 04, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
my grandfather has this problem on an RCA projection as well...they fixed it twice already....still showing the same problem.red and greens are off.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 24, 2007
Thanks for Trying (70)
srtech
Rank:Wiz Wiz
Rating: 82%, 238 votes
get an estimate to fix your convergence problem
Can you Help with these Projection Televisions problems?
tv help
hi i got the fuse out it in,... Answer This...
big screen tv
I have a RCA P52937SG that is... Answer This...
toshiba 36HF71
i have picture but screen is... Answer This...
the colors are weird. the white...
i tried the convergence on all... Answer This...
Convergence problem
the manual states to go to the... Answer This...
6 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 11, 2007
The picture sags on the top bottom and sides.  it looks like to picture is being sucked into the middle of the screen.
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
