Question about Mitsubishi WT-46809 46" Rear Projection Television
MItsubishi WT 46809- not staying on when turned on
My Mitsubishi WT 46809 is doing the same as described before. The TV clicks on, no image appears and the "timer" light turns green and it then shuts off in about 10 seconds.
  • 1 more comment
  • rdeage Nov 18, 2007
    Is it possible to buy the appropriate fuse and replace it without a lot of technical knowledge?
  • sohonet Apr 03, 2008
    unplugged for about 3 weeks. Plugged in, worked fine for hour and shut itself off. turn on, stays on for 5 seconds and shuts itself off. Unplugged for 2-3 hrs, re-plugged in. stayed on for 15-20 seconds, raster came up, and shut itself off. turn on again, stays on for 5 seconds and shuts itself off. unplugged for 48 hrs, it stayed on for 30 minutes with no problem. I'm expecting a charging overload thing. Not likely a thermal, that I can see.
  • Anonymous Feb 16, 2009
    My tv
    Genius:
  • 1,694 Answers
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
  • Vista Electronics Nov 04, 2007
    This repair is normally done by a skilled Mits tech.....T.
SOURCE:
My Mitsubishi TV Model WT-46809 has the picture turn greenish pink after the TV has been on for a little while. What is the possible cause?
These sets did have one common issue where red, green, or blue would do what you are describing.
The set has 3 picture tubes and each has a small circuit board plugged to the bottom of it (bottom of the tubes faces down) and a ground would break loose or a part do the same.
I would examine the picture (see if you can take one and post it somewhere for me to see---picture will tell me a lot).
The ones with the ground broken usually show it more on the sides then in the middle of the screen.
Let me know all you can.
I am a top expert on this site.
Mar 19, 2012 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809 has convergance issues
Replacing the Convergence IC's should do the trick. But it is not a easy repair do to the disassembly requierments. I would recommend calling Mitsubishi at 18003322119 to get a local service facility to come out and give you a estimate to repair.
Jun 21, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Color Gun Help?
this tv will need some testing to determine the exact cause but most likely it will need a conversion done, you will need to call your local repair shop to come out and fix the problem
sorry about your tv
electech
Oct 26, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Turns on with Power light then turns off
there are 2 fuses -24v and 24 v normally would go out because
covergence ics failled . That would be a shutting down problem cased by missing those voltages.so you would need to replace those 5A (small green fuses) , you would need some kind of soldering and unsolderin skill) and the ics are stk392 570.two also. open the set from the fron ,taking speaker grill off and then the wood board behing (4-6 screws) you the the board in the center big metal heatsink. you would need to work from the back to repace those puppies.hdtvman
Jun 07, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 Vertical Deflection Failure
the vertical output IC may need re-soldering or it may be defective and need to be replaced. my guess would be bad solder on the vertical IC.
Apr 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Wont stay on
I can help u fix in live chat!
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
324 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
