Question about Dell E152FP 15" Flat Panel LCD Monitor
Dell monitor problems and solutions - Dell E152FP 15" Flat Panel LCD Monitor
I have Dell 2320L bought 3 days ago, When ever there is white screen, sometimes it happens that the monitor flickers not too much but it does which distracts my attention. Any solution ?
You might have a problem with the monitor. Get the computer and conect it to another monitor. Then on the desktop, right click on the desktop and go to properties.
In the properties, go settings, then go to advanced, then go to monitor and on the monitor tab, look for monitor settings, and select either "use default hardware settings" or 60Hz and select the box that say hide modes that this monitor can not display. Tha should solve your problem....
Sep 27, 2012 | Dell Computers & Internet
Dell Monitor Failing
its the problem in the EST of the monitor.just get it replced to solve the problem.
pls do rate the solution
thanks.
regards.
fixya expert team
Sep 02, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 1702FP gets off automatically or lose power by itself!
i think the power cord to your monitor is not fixed tightly. check the connections. or else the power On / Off button could have got damaged. replace it with the new one. if still the problem exists, servicing of the monitor will be the solution to it.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Help me please
You got a common problem caused by bad transistors. Here is the solution:
http://josepino.com/?howto-repair-dell
I do not recommend you to follow the instructions if you don't have previous electronics repair experience.
Sep 30, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Problem with shadows showing on monitor
LCD Monitor Shadow Effect
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this is very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
Solution: Keep the two cables - (power cable and monitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Nov 02, 2007 | Dell Computers & Internet
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E173FP - After sometime the screen switches off
Sorry not a solution - but I have started experiencing the exact same problem over the last month although sometimes, on switching on again, it will run for 10-15 minutes before the problem re-emerges. Initially I put it down to the v. hot weather in July but it still continues. So I would also appreciate any solutions!
Aug 06, 2006 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E152FP 15" Flat Panel LCD Monitor Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
