Question about Cuisinart DLC-8S Pro Custom Food Processor
Food Processor assembly
I got an old version of the cuisinart food processor DCL-8M, it doesn't have a manual and I want to use to make mash potaoes. Unfortunately, I have no clue how to assembly the right part to do it. I'll appreciate any help you can give. Sincerly, Jane Fawcett
Hi Janne,
I bought a DCL 8M about 20 years ago and still have the original manual. Mashing potatoes is one of the few tasks that the manual discouraged. The potatoes turn into glue. I tried mashing potatoes with the flat blade and extra liquid. It still tasted awful. I do puree potato soup in batches, First I mash all the solids (potatoes and leek or potato and tomatoes), then add the liquid. For some reason, pureeing the soup works well.
I am sorry I could not be more helpful.
Myriam
Posted on Sep 11, 2008
SOURCE:
Manual for sunbeam multi processor model no Le 6250
Google (sunbeam)(Le 6250)(manual) without parens.
Aug 23, 2018 | Sunbeam Food Processors
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 12, 2009 | Cuisinart Food Processors
My Cuisinart food processor won't start!
Make sure work bowl handle is locked in so that the handle is facing the front of the processor, and that the feed tube and metal rod of the pusher are facing the back of the processor. If it is assembled in this way and still won't turn on, call Cuisinart for assistance, as you may have concelaed damage to one of the work bowl parts. 1-800-726-0190
Jul 27, 2009 | Cuisinart DFP-14BC Custom Food Processor
Cuisinart Processor workbowl lid fitting
Cuisinart DCL-7 replacement work bowl lid is cuisinart dlc-017bgtx work bowl lid fitting with large feed tube.
Jun 05, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Instructions for the food processor of my Cuisinart Duet
Place the gearbox on top of the blender/food processor
Place the work bowl over the spindle, with the handle facing the front of the machine - make sure the tabs lock into place.
Place the stem adapter on top of the spindle, then the blade.
Place the lid on top of the bowl, with the feed tube facing the back of the food processor. Then the pusher into the feed tube.
Here is the link to the user manual with visuals 9p.6 is most helpful):
http://www.cuisinart.com/share/man/10_man.pdf
-Tha Mp3 Doctor
Mar 23, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Need a instruction book or manual for cuisinart 7 cup food proces
All manuals for models made in last few years are on Cuisinart website.
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Dec 07, 2008 | Cuisinart DLC-5 Food Processor
Cuisinart DLC- 8M
Those older Cuisinart food processors have motors that generally last forever. But a replacement bowl can cost $118.00 or more. The newer processors like the DLC-8S do have a 3-year general warranty and a 5-year motor warranty. The new DLC-2011, 2007, 2014 series etc. have 10-year motor warranties. I like the collect the oldies, but the new ones have few problems even though they are made in China. If an old processor's plastic breaks, you have to buy a completely new bowl set - if a new processor's plastic breaks, then you can buy a single component piece to solve the problem. Hope this helps.
-Tha Mp3 Doctor
Sep 19, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
My food processor plastic container has never slipped on and off with ease i have to smash it into place and the double smash the handle to remove it from the base. I would like to get a new upper...
You can get a completely new work bowl set (not the original parts) from Cuisinart for around $118.00. You could also buy one from a shady eBay seller and see if the oldie works. I am a collector of these myself, but in reality, it is probably cheaper to get a new Cuisinart food processor - they are nearly as good as the old ones.
-Tha Mp3 Doctor
Jul 02, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
Need manual for food processor
Found it at:
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DLC-10S-_E
Apr 08, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-8S Pro Custom Food Processor Logo
295 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Bruce Showalter
Donni Steen
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
