Question about Proform 67651 Vehicle Weighing Scale 7000 lb. Wireless 4-Pad System 1750 lbs. Per Pad
ONE SCALE PAD IS GIVING WRONG READING - Proform 67651 Vehicle Weighing Scale 7000 lb. Wireless 4-Pad System 1750 lbs. Per Pad
    Problem Solver:
  • 15 Answers
Maybe strain gauge is disrupted. If you could check the internal parts, there should be 4 wires. Using an ohmmeter, reading should be equal on two pairs: around 350ohms and around 150ohms. If reading is different than this, then your load cell is burned.
You can also check the same reading with a working pad. It should be the same.
One other problem that may occur is that the cable going from one pad to the main system may be torn. Since it is a millivolt reading, it will ruin your measurement.
Posted on Nov 22, 2013
Scale is reading F--H
Mine did this also, I got a replacement and it also read F--H. I took all the screws out - they hid them under the bar code sticker and under the stick-on faceplate where the buttons are - then found that the screws on the load cell which is sort of like an aluminum tuning fork had been tightened so much that the cell was reacting to the screw force, not the scale pad. Release all the pressure and you may be able to make it come alive again. One of my two is working now but calibrating is another thing all together because the linear counting depends on the loadcell screws being set just right.
Jun 03, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My health o meter bathroom scale is giving me several different weights suddenly. I have replaced the battery and that did not fix the problem. Suggestions?
You need to make sure your scale is on a hard flat surface to keep a consistant reading. If that does not correct the problem I would call the manufacturer and look into a replacement.
Nov 13, 2010 | Home
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
How do you program users?
Storing and Recalling Weights
1. Your scale can store and recall up to 5 weights. If your scale has one button,
weights can be stored for one user. If your scale has two buttons (User and
Save/Recall buttons), weights can be stored for multiple users.
2. Tap center of scale platform with foot and wait until "00.0" appears.
3. Stand on the platform without shifting or moving until weight is displayed.
4. For single user scale: When weight reading appears on screen, step off the
scale, press Save/Recall button and hold for about 2 seconds to save the
reading.
For multiple user scale: When weight reading appears on screen, step off the
scale, and press User button to select a user number. Then press Save/Recall
button for 2 seconds to save the reading.
5. Weight reading blinks twice, then becomes stable. A small number (1-5)
appears in the upper right hand corner of your display, indicating which of the
5 weights is displayed. (Once you have 5 weights in memory the current weight
always saves as "1" and the oldest reading is eliminated.)
6. Weight reading is saved. Press Save/Recall button to review the last 5 weights or
let the scale shut down automatically. (Note: until you have 5 weights stored in
memory, the display will show the number and "–" for each weight for which
no data point has been stored yet; i.e. "3 –", "4 –", "5 –" if only 2 weights
have been saved.)
Hope this helps!!
Feb 09, 2009 | Precision Camera Weightwatchers WW70 Body...
Java source code
* To change this template, choose Tools | Templates
* and open the template in the editor.
//package optimalcluster;
* @author CSEEXAM2008
import java.awt.*;
import java.awt.geom.*;
import javax.swing.*;
public class GraphingData extends JPanel {
double[] data = {
0.504782921308152, 1.174144134378306, 2.0933754535558546,6.2625807939548823,8.8484441414277364,10.0000003,12.908978000,14.8906789456,12.9087654567 };
final int PAD = 20;
@Override
protected void paintComponent(Graphics g) {
super.paintComponent(g);
Graphics2D g2 = (Graphics2D)g;
g2.setRenderingHint(RenderingHints.KEY_ANTIALIASING,RenderingHints.VALUE_ANTIALIAS_ON);
int w = getWidth();
int h = getHeight();
// Draw ordinate.
g2.draw(new Line2D.Double(PAD, PAD, PAD, h-PAD));
// Draw abcissa.
g2.draw(new Line2D.Double(PAD, h-PAD, w-PAD, h-PAD));
double xInc = (double)(w - 2*PAD)/(data.length-1);
double scale = (double)(h - 2*PAD)/getMax();
// Mark data points.
g2.setPaint(Color.red);
for(int i = 0; i < data.length; i++) {
double x = PAD + i*xInc;
double y = h - PAD - scale*data[i];
g2.fill(new Ellipse2D.Double(x-2, y-2, 4, 4));
g2.setPaint(Color.black);
g2.fill(new Ellipse2D.Double(x-2+4, y-2+4, 4, 4));
g2.setPaint(Color.blue);
g2.fill(new Ellipse2D.Double(x-2+6, y-2+6, 4, 4));
g2.setPaint(Color.pink);
g2.fill(new Ellipse2D.Double(x-2+8, y-2+8, 4, 4));
private double getMax() {
double max = -Integer.MAX_VALUE;
if(data[i] > max)
max = data[i];
return max;
public static void main(String[] args) {
JFrame f = new JFrame();
f.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
f.add(new GraphingData());
f.setSize(400,400);
f.setLocation(200,200);
f.setVisible(true);
Feb 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
1992 jeep wrangler oil pressure goes off scale while accelerating
try replacing the oil filter and oil make sure u use the right grade oil for it if it still does it u need yo go to mechanic or if u have one connect a external oil pressure gauge to the engine to check if the car gauge is reading correctly if it is reading right then the oil pressure releif vale is stikking
if the car gauge is reading wrong change oil pressure sender
Dec 20, 2008 | 2002 Jeep Grand Cherokee
Proform 67651 Vehicle Weighing Scale 7000 lb. Wireless 4-Pad System 1750 lbs. Per Pad Logo
55 people viewed this question
Top Proform Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Proform Measuring Tool and Sensor Expert? Answer questions, earn points and help others
