Question about Logitech Z-5500 Computer Speakers
No sound coming from logitech z-5500 - Logitech Z-5500 Computer Speakers
3 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: no sound coming out of z-5500
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
Try these articles as well:
Manual
Setting up the Z5500 with PC, Mac, Xbox, Playstation, DVD Player, etc.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 24, 2008
  • 185 Answers
SOURCE: Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Posted on Jan 06, 2010
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
I don't have a sound card.but how can i connect logitech Z-5500 speakers to my pc
Since Logitec Z-5500 is a 5.1 Speaker System you need to purchase a Sound Card to be able to connect it with your pc. You can get a Sound card starting with a price tag of 20 Pounds.
Hope this will help you solve your problem Best Regards NextDoorNerd
Jul 28, 2010 | Logitech Z-5500 Computer Speakers
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
How can I connect my logitech Z 5500 to a sony bravia KDL-32U3000
You can buy a Digital Coax audio cable from any electronic store, this will be a single cable that will connect from your z-5500 to your TV.
Oct 11, 2009 | Logitech Z-5500 Computer Speakers
Like i have everything hooked up and everything set to 5.1 sound but there is no sound coming out of the speakers at all, i plug my headset in and it works but not the z-5500
If you have already checked to make sure that you did not mute the source of your audio, the problem is either with your cabling, or the Z-5500 itself. If your still under warranty then take it to your local Logitech repair depot. If you are out of warranty you may want to order new cables from them to see if that is your problem.
Jul 10, 2009 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound coming out
Hi there, Mr Dan
Happy Holidays
well, you can change, the coaxial cable for another optical? is better, if you got an optical input. or optical output to input on your SPK. that should work.try the test with a movie on.or sound continue.
Dec 18, 2007 | Audio Players & Recorders
Im looking for a part for my z-5500
www.curryspartmaster.co.uk You should be able to find what you are looking for here or alternatively go to logitech themselves http://www.logitech.com/index.cfm/change_location/&cl=gb,en&returnurl=support_downloads You could also try e-bay for the part as you are bound to find it much cheaper Still having problems just let me know.
Aug 11, 2007 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
53 people viewed this question
Top Logitech Audio Players & Recorders Experts
gunzmith
Level 1 Expert
Henry  Thomas
Henry Thomas
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
