No power indicator light and no function at all when power is pushhed
This could be a multitude of things. The first step is to make sure your charger is working ok. Many chargers have an indicator light of some sort on the power brick halfway through the cord. Check to see if yours has one, and if so is it on? If not check all the connections, but your charger is probably bad.
If the light is on, the charger is probably fine. It is relatively common for the interior DC jack of laptops to have a bad solder joint or something, especially if the cable has been tugged on or something of the sort. Let me know what you find out and we can decide what to do next!
SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
SOURCE: VAIO PCG-8Y2L won't boot - no display, no nothing....
I smell a Hardware fault,or your Display might be busted...I suggest you Visit a PC store and let them check it out.
SOURCE: I have a Sony VAIO PGC-272L that ignites the
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jodiki99
SOURCE: sony vaio pcg-r505el won't turn on
These are know to have issues with the cpacitors on the mother board, you can try to replace the caps or just buy a new motherboard. I'm fixing one right now as I type...
SOURCE: My sony Vaio PCG 272L
Hi chris_rovie3.
Based on the information you have provided, the issue might be due to the Battery or the Power settings.
As the issue might be due to the Power Unit in the Notebook, this might also be related to the Hardware problem(Power Unit).
Hence, it would be better to get the Unit examined at the authorized Service Center.
However, you may first try performing the troubleshooting steps which I have mentioned below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C390934&fes=true&mdl=PCGK33P
The above link has all the possible troubleshooting steps.
Hence, please try performing all the troubleshooting steps mentioned on the page.
Performing the steps should resolve the issue.
If the issue still persists even after performing all the troubleshooting steps, the issue might be Hardware related.
Hope this helps.
Please feel free to contact for further information and assistance.
