Question about Hitachi 50V720 Television
Blue area near center of screen
I have recently, within the last 6 months replaced my bulb, and in the past week have just noticed a blue cloud near the top center of my screen. I have tried to reset and it won't go away. I have just started using a HDMI cable that looks like a USB cable and have noticed it since then. Also ever since I have been using the HDMI cable there is a pop when I turn off the tv. We have direct tv and have made sure that my connections are tight. not sure what to do or try next please help. thanks!
  • 8 more comments
  • Anonymous Nov 09, 2007
    Have blue cloud in center of screen on Hitachi 50V720. Bulb less than a year old !
  • Obliv Jan 11, 2008
    We also have the same blue area...developed about 4-6 months after replacing the bulb. Based on what I read here, we are calling Hitachi first thing in the AM !!!
  • Anonymous Jan 27, 2008
    we replaced bulb 4 mths ago and we now have blue area in the middle of the screen
  • handsup Feb 03, 2008
    I have the same damn problem....just replaced my light bulb 3-4 months ago and the "blue" cloud has now recently appeared in the center of my screen. I was quoted $7-800 dollars for it to be fixed and it takes 2-3 hours to complete.
    has anyone had any luck on getting Hitachi to own up to their flaws?
  • Anonymous Feb 05, 2008
    I have the same problem and only days after replacing my lamp. I am TICKED OFF!
  • Anonymous Jun 23, 2008
    Same problem. Replaced the bulb and 3 months later the blue haze appeared. Called Hitatchi and they wanted to convince me this was not a known issue with this set. Convinced them to provide the part...which of course is on national back order. Gee if this was not a problem, how come the part is not available. When I called the servicer and told them what set I had..the first question was..have you called Hitatch yet? Before..I even told them the problem...
  • 61914 Jul 08, 2008
    Developed a blue haze down the center of the screen, larger at the top, tapering out as it went from top to bottom. This problem showed up one month after replacing the bulb. Opened up the bulb compartment thinking it was the bulb, but it was okay. Cleaned the light engine lens, and removed a coating of dust, and a smoky looking compound. By shining a light onto the light engine lens, I could see a milky looking coating on the inside portion of the lens. So far I do not know how to clean that area, and I beleive if possible it would clear up the problem. Maybe the high heat generated when the original bulb burnt out, caused this smoky film to be deposited. I am going to call Hitachi and see if they will do anything to cure this problem. 62VS69A purchased 11/2007, replaced bulb 3/2008, and now have a blue haze picture to look thru.
  • rolech Aug 13, 2008
    Blue area showed up on left side of screen about 2 months after lamp replacement. Luckily I have a service contract with Sears. I was told projector needs replacing and my service contract will cover the $1100.00 cost.
  • keeys Aug 28, 2008
    just replace my bulb a few days ago and I too now see a damn cloud. what the heck is this problem?
  • shaun_beck_ Dec 11, 2008
    i think i have the same but when i change videos input 1 to 3 it changes. i dont use input 3 and there is no purple at does any else have this.
I had the same problem with the screen turning blue after I had the bulb change. I just had to watch the tv with the blue haze, could not afford for another repair man. The bulb cost me over $400.00 to get it fix. So after about 6 months or so, the blue haze kinda faded away to a lighter yellowish tint, then you could not notice it at all, but the screen started to get darker. I just thought it was these movies made in a darker screen. But Guess what: my blub blew again.
It cure the blue tint. This time, I will order the bulb and put it in myself. If I knew about these bulb, would not had bought the tv. Other than that I like the tv. showed a good picture before all this bulb trouble. Why in the world does a bulb cost this much??????
JWHITE
Posted on Jul 28, 2008
It may not be the light engine. I also have the cloud, and since I was told that touching the bulb surface could cause problems, I took out my bulb to take a look. The fault is Inside the bulb. A cloud has formed on the inside of the bulb dead center. I have a feeling this is the problem and replacing the bulb again is going to be the solution. By the way, I buy the bulb alone and put it in the casing myself. The last time I got a replacement the casing was slightly and I do mean slightly, out of line with my set.
Posted on Feb 27, 2008
  • 579 Answers
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Posted on Dec 31, 2007
SOURCE:
Bulbs keep blowing
You may be touching the bulb (ampule) and leaving a fingerprint on it which creats a hot spot and blows the bulbs up prematurely.
Mar 25, 2013 | Mitsubishi WD-65731 65" HDTV
Sony wega lcd tv blue dots
thats caused by the optical block which is very expensive to replace. Sony has had alot of issues with the blue dots on the screen its not worth repairing due to the high cost of the optical block
Feb 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
Buick 97 LeSabre hard start and acceleration issues
Have you checked the catalytic converter? After 20 years they do pug up causing some of the problems you describe
Apr 09, 2017 | 1997 Buick LeSabre
Dim screen ruining my Hannspree
your LCD screen backlite bulbs are bad or the inverter card the drives them is going bad
Oct 02, 2009 | Computers & Internet
Bright blue patch in center of screen.
The optical block is going bad. Contact Sony support and have your model and serial numbers handy. Sony sometimes warranties these even after the 1yr factory warranty.
May 16, 2009 | Sony KDF-42WE655 Television
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Hitachi 50V720 Television Logo
381 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
