Question about Indesit Washing Machines
Flashing lights on indesit wia101
Anti crease and door lock light flashing during cycle. just after or during heating.
informatica
  • 1114 Answers
SOURCE: INDESIT WIA101 INSTRUCTION MANUAL
Hi - You can download the manual from the link underlined in blue below:
WIA101
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 09, 2008
SOURCE: indesit washing machine will not drain and carry on with full cycle
Already posted previous comment. Thermistor measured resistance of c 30K ohms on meter - that seems OK. However one of the wires on to the thermistor plug looked faulty and came away when touched. Needed carefully soldered - it looks like a "punchable" connection eg BT phone socket but it ISNT <grin> Washer now working fine. (Had previously a broken front concrete block under warranty so drum shaking about more violently than usual due to that had obviously weakened this thermistor connection....)
Posted on Aug 23, 2008
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
blueextc3221
  • 15935 Answers
SOURCE: door lock light flashing,rinse light flashing and
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
  • 32 Answers
SOURCE: indesit wixe167 won't start no doorlock light
you need to change the door switch by a new one
Posted on Oct 12, 2011
How can I stop the lights from flashing mid cycle and make the machine continue its cycle to the end and drain?
first you need to take off the drain hose that allows the water to pump out and check to see if it is blocked at the part that it connects to from the machine , you could try to blow back the water but if its blocked i doubt it , after you remove the hosing inspect the inside of where it fitted onto , with the cord unplugged from the wall you might be able to use a bit of wire with a tiny hook bent onto it and pull out any blockages . also make sure the water pump is engaging when it goes into the pump cycle .
Aug 07, 2017 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Cycle is not finishing and the red lock light and green anti crease light is flashing
I am sorry, I have no specific manuals or experience with this machine. Another expert should pick up on this and hopefully will provide you with a good solution.
Nov 25, 2011 | Indesit Washing Machines
Bosch Classixx condenser dryer not heating and turns itself off.
Most likely the heating element or a thermostat.
Oct 12, 2017 | Dryers
WIA101
Aug 09, 2008 | Indesit W 123 Front Load Washer
Indesit washing machine will not drain and carry on with full cycle
Same problem - changed module with no result. Looks like the water temperature thermistor...
Jun 12, 2008 | Washing Machines
Nov 01, 2007 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
