Question about Gestetner DSm725 All-In-One Laser Printer
Printing blank pages after drum replacement - Gestetner DSm725 All-In-One Laser Printer
2 Suggested Answers
Dicedonions
  • 118 Answers
SOURCE: Replace photoconductor unit
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, for settings, check to ensure everything is order.
lastly, check make of printer trouble shooting web site for more information
hope this helps, good luck.
Posted on Apr 29, 2010
My hp 1010 prints only the first page. but from the second page it gives blank print. please help
shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace
If no image any ware replace "Power supply PCA"..
Sep 10, 2011 | HP LaserJet 1010 Printer
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
It has plenty of ink and the drum is good but it stopped printing
All blank pages could either mean: On the scanner side: * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the scanner side by printing a test page on the printer. If it prints fine, the problem is in the scanning process.
On the printer side: * Dirty connectors between toner/drum unit and machine. Remove the toner/drum package and clean the metallic cylinders on the left and right side of the toner/drum unit, then reinsert package into machine. * Bad toner and/or drum unit. Replace should solve it. * Mechanical error, you'll need to perform service on it to reanimate it again. * You can check if it is on the printer side by either scanning to a connected PC or sending a fax to someone. If the scanned/faxed page looks fine on the pc/fax that receives the fax, the problem is in the printing process.
Jun 02, 2009 | Brother MFC 9700 All-In-One Laser Printer
I get blank pages when printing. Sometimes all pages are blank, sometimes first and last page print, with blank middle pages.
hi,check your printing setting and then print.
or....
uninstall the printer then install the printer again then printer has default setting and print the paper.
sometimes printer current pages print wich is selected by setting.you must select all the pages.
to change the setting,,,
1-open control panel then open printers and faxes then check seeting.
Apr 12, 2009 | HP DeskJet 842c InkJet Printer
My HP color laserjet 4500 is printing only blank pages
This is usually the Transfer kit, but if the image drum or one of the power supplies goes bad, that can also give blank pages. The Drum problem for no print is usually a grounding/connection problem. Power Supplies are a complicated repair, but these printers aren't too bad to work on. You can buy good used one's fairly cheap on ebay, though. Should consider going to a later model CLJ if you replace with a used, though.
Apr 07, 2009 | HP LaserJet 4500 Printer
OKI C5600 printer is printing Blank pages
you looking at 3 posibles one is the scanner may need to be replace or the low voltage power supply or you looking at a posible drum problem
Nov 22, 2008 | Ricoh Aficio 250 Copier
Fax 2820 will not print. pages are blank
what do you mean printing stage?for the blank pages,it may only require cleaning.check the toner save setting,make sure it is off.clean the scanner glass of the machine,or you may just need to replace the drum
Nov 15, 2008 | Brother IntelliFax-2820 Laser Fax
Print error
Replacing the drum should fix this issue. The PC drum, aka, photoconductive drum, is light sensitive, if it has been exposed long enough to light, it can cause this problem.
Jun 19, 2008 | Dell 1720dn Laser Printer
AR-M455 Printing Blank Pages
hi im jules_09.try checking the transfer roller or the drum charge roller or charge wire both of this unit are responsible for blank copy.either there id a current leak on those parts or your drum and transfer power pack is deffective.is the opc drum not expose to light morethan 8minutes?just check the transfer unit then the drum charge wire or roller
Nov 05, 2007 | Sharp AR-M455N Copier
Gestetner DSm725 All-In-One Laser Printer Logo
13 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
