Epson Stylus Color 740 InkJet Printer
Problem for Epson Stylus Color 740 InkJet Printer
Epson740 all three red lights flash power on/off does not clear.
By paul_hopton on May 06, 2009
This is the first time my Epson 740 has failed to boot up correctly as all three red lights keep flashing.
Solution #1
posted on May 06, 2009
Not Rated)
websnail
Rank: Guru  Epson Expert
Rating: 92%, 209 votes
Hey Paul,
Just checked the service manual and you have finally reached the "Service required" point in your printers life...
I used to have a 740 many moons ago but have never taken one apart so I can't provide too much in the way of direct experience but I think you'd be relatively safe to take the printer apart enough to access the pads, remove, clean, dry and then replace them without too much hassle.
Resetting the waste ink counter shouldn't be too difficult either as the 740 is supported by the SSC utility...
If you want a copy of the service manual visit www.octoink.co.uk and use the contact form to request it and I'll send it along..
Hope that helps.
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus Color 740 InkJet
Questions and Unsolved Problems for Epson Stylus Color 740 InkJet
Do you recommend Epson Stylus Color 740 InkJet Printer?
Answer
Answer
print head out of sync and making a screeching noise and the head appears to bang on the end of... (More)
Answer
my epson 740 color printer does not work after several years
Answer
keep getting message jobs stopped and i don't know what to do
Answer
what should be the power supply if it happens that the fuse is ok?cause the power supply i'm using... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus Color 740 InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
