Question about RCA 32V420T 32" TV
TV cutting on and off
I have a tv that will cut on and off by itself. I removed it from the cable box and got the same thing. I was thinking that the remote was giving off signals because the batteries were low. The menu up/down buttons now cut on the tv but the power button does nothing. During this time, it stays on for a few seconds on Chaneel 3 MONO. It will them just power off and on repeatly. Thanks in advance for your help.
  • george1974 Oct 28, 2008
    the tv will cut on and off by itself after being on for only a few minuetes and while it is on the remote will work when it wants to also the manual keys will not function either it will all work when it first comes on but after a few minutes this all begins.
  • 149 Answers
Hi there, you do have some electronic parts to be repalce. do some testing at the power supply section and replace the defective parts. ty
Posted on Dec 24, 2007
JVC 42" Tv has cut off and when it came back on
If using a cable box try connection direct without the box---also try to remove power from set and box for a while and then power back.
Dec 03, 2012 | Televison & Video
MY VIZIO 37 INCH TV
I think you may have the same thing going on that we had happen several times, I think its stuck in RGB mode. Go to the TV itself, and turn it on manually. As SOON as you turn it on, hold the input button on the side of the TV for 30 seconds. This should get it back to the normal TV mode. We got this fix from Vizio ppl.
Jul 12, 2012 | Vizio VX37L Television
Heads are cut off on toshiba tv and reading at bottom
Depending on the model the set or a cable box may have an adjustment for this---simple thing to do also is hook to DVD player via rear inputs to see if same problem or not.
Apr 20, 2012 | Toshiba Televison & Video
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
My HDMI connection from my Dish box to the TV has a bad connector at the box connection. How do I fix this? This connection has a 15 ft run from the box to the HDTV. I was thinking about cutting the...
I wouldn't cut the cable , Is the cable faulty or the socket, You could have tarnished contacts. One thing you could try is spraying the lead and socket with switch cleaner. (a great airosol that cleans contact surfaces) then try a new hdmi cable. You said it was 15 mtrs. Why not move tv nearer & try
a short cable just to prove if cable is the fault.
pete
Nov 08, 2010 | Televison & Video
Tv cuts off by itself . I turn it on using a cable digital box. Blue light comes on, tv operates for a short period, then an orange light comes on and tv cuts off.
i think its a problem with a lose cable or something inside it
sorry i couldnt be of more help
take it to a repair man for diagnostcs at any point its not something you can fix
Sep 19, 2009 | Vivitek Televison & Video
How to connect dell laptop to samsung 29 inch tv using cable
Dear Sir,
For getting display in TV you have to select input source as TV generally in all other laptop
short cut key is fn+f4. generally short cut function key shows picture of small square box.Search for that short key then activate the out put for TV by pressing that key with Fn keys.
I think it solves your problem.
good luck
Aug 27, 2009 | Samsung CW29M64NS 29" TV
Tv turns on and turns off after 5 seconds
jim if know how to soldering iron ,resolder your tv especially the power supply
Jan 26, 2009 | Televison & Video
Sound cuts out- cable tv
I had the same problem when I installed the new HD Comcast cable box (DCH3200), initially with my CRT through RF, then with my HDTV through HDMI. Problem solved when I replaced the box with the Comcast RNG110 I got from my local Comcast. It is a neat miniaturized box and it works extremely well on HD. There is no power switch on the box so before activation do not forget to put it on with the remote (cable, power, the green light will come on).
Aug 09, 2008 | Sony STR-DE595 Receiver
PICTURE CUT OFF
Push the "Ratio" button on your remote and see if that helps. I am assuming you are connected to either a cable or satellite box. If pushing ratio doesn't work, it may be a setting in the box. Post what kind of box your using and I will see if I can help.
Jan 22, 2008 | LG 42PC3D 42 in. Plasma Television
RCA 32V420T 32" TV Logo
59 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
